need more fuel pump!!!
Car is a 99 camaro plastic tank - current squash hanger
My base pressure is a little high of 55 with boost reference. 25psi of boost puts me at about 80 which like i said is a little high for walbros.
I know dropping base down to about 43 will help out some but im looking to make over 1100. for now
My options -
1st - Triple 450s in tank
2nd - Stock bucket, bulkhead fitting -8 to fuel filter. SINGLE 450 as well as a bulkhead on bottom of tank with magnafuel 4703 on a hobbs switch. with a Y into the fuel filter. Also have a switch for manual overide over hobbs if your flat out at the track.
Last is a single pump in tank to a surge tank with a 4703 feeding from hobbs.
I have a buddy on a similar car who ran out of fuel with his 4303, thats why im looking into the 4703. E85 car.
Stock pcm as well!
Any input would be great guys. thanks!
A pair of 450's should be able to do well in excess of 1k on pump/race fuel without worry.
Is fuel pressure dropping ? How are IDC's ?
Size of lines, filters etc ? How is wiring, voltage at pump under load ?
You could BAP on one of the pumps which would offer a decent improvement. Not sure if a BAP could tolerate two of those pumps.
https://ls1tech.com/forums/fueling-i...fuel-pump.html
That serves no real world purpose.
And if you want to see what work either pump is doing regardless of perceived pressure/flow, measure pump current.
And pretty sure the 044/AEM will be ( trying to ) outflowing your 255 at all times in that test, so not really able to contribute much ?
My options -
Stock pcm as well!
What you need to do is put in the proper size injectors so they will flow the appropriate amount of fuel at 43psi or even slightly lower (maybe 35) if desired. Then your pump capacity will increase as the pumps are operating at a pressure they were designer for.
Correct what needs fixed instead of trying to band-aid it with parts you do not need. Otherwise you will end up ruining pumps & blowing out internal fuel lines & end up with more problems.
I have Id2000s at 71 percent duty cycle. I think you may be refering to pump gas or a race gas. I have never seen once a e85 car clip 1200whp in an auto application. Everywhere rates twin 450 pumps at 1200whp which stick shift guys accomplish. am i missing something?
Voltage is fine. 13.4ish underload. -10 feed split to -8s before the rails. large regulator. both pumps have there own relays and circuit breakers. my tuner said pressure is dropping.
