4 bolt DBC throttle body
Old Jan 24, 2018 | 04:46 PM
deputydog's Avatar
Default 4 bolt DBC throttle body
I'm new to the LS engines so bear with this question isf it's dumb.
are there any years you can get a 4 bolt DBC TB? All I see is the 3 bolts and am looking for factory DBC 4 bolt TB and prefer not use the adapter.
Thanks
Old Jan 24, 2018 | 04:49 PM
There are lots of aftermarket ones.
Old Jan 24, 2018 | 05:21 PM
deputydog's Avatar
Are there any factory ones? Building budget 5.3 turbo so I don't need NW or 400 TB. I see cheap EBay ones but read on here some have issues so thought I would stay factory
Old Jan 24, 2018 | 06:07 PM
The only factory cable throttle bodies were in Trucks and Gen 4 Camaros, and all those were 3 bolt. The larger 4 bolt ones came out in Corvettes (LS2 initially) and the later trucks, which were all DBW.
Old Jan 24, 2018 | 06:34 PM
deputydog's Avatar
Thanks....two questions then. Are there any issues running the adapter from 4 bolt intake to 3 bolt TB?
and are the Holley Sniper TB ok? They are priced in the 160 range which is reasonable. again this is turbo deal so I don't need a big one
Old Jan 24, 2018 | 09:34 PM
While I have no experience with their TB's, Holley usually makes a good product, and they back them up.
As long as there are no flow "hiccups" between the TB and manifold, there should be no problem with the adapter
Old Jan 25, 2018 | 11:55 AM
nuckifuts's Avatar
I have a ProComp i would sell cheap $40. I switched to a FAST on my Nova. I did not realize there was a set screw that holds the throttle lever or arm to the throttle shaft until i took it off to replace it. I kept having issues with it returning to idle.
Old Jan 27, 2018 | 08:15 AM
01ssreda4's Avatar
WARR throttle bodies are fine man, some say locktite the blade screws but thats it. Will crank up and idle like stock.
