Single Racetronix 255 supporting 670rwhp on E85???
I bought this car 2 years ago and was told it has a single racetronix 255. With a 408 and nitrous, (200hp shot??) It dynoed 670rwhp thru a 4L80e on E85 fuel and 60lb injectors. Does this sound right? I would think it would need alot more pump. It was tuned by Sam Miller.
Thats the old setup, i sold it awhile ago.
Whatever it had for a fuel pump is still in the car.
I wanna know if the fuel pump will support 600-650 from a procharger on 93 and/93 and meth, with a 6 speed.
It did 670 with nitrous that had a dedicated fuel system, on e85 thru a 4l80e.
Im not sure how much the dedicated fuel system helped in that setup?
I've been told a single 255 pump (no hotwire kit) is good for maybe 525-550 rwhp. That's running pump gas of course. No way will it support 600-650 rwhp from a blower
If it is in fact a 255, then that dedicated fuel help a **** ton to support a single 255 handleing 670.
I just dont know how much that dedicated fuel setup helps.
It might be a Walbro 340 or 450 in the tank for all I know.
If whatever pump is in there supported 670 on e85 thru an 80e...It should have no issue with 600-650 on 93 thru a 6 speed.
That I can't say for sure. You have a lot of variables between the two setups. On one hand you have E85 drawing like 30% more fuel but running n/a with a dedicated fuel for the nitrous. Then on the other hand the blower drawing more than n/a regardless of fuel type. I'd call someone like Lonnies Performance and see what he says
Procharged here with a single raceteonix 255 and hotwire. Pump maxed out at 550rwhp. Maybe with a boost a pump 650 but definitely not just the pump and hotwire.
I would say 600 is about the limits of the 255. 670 on E85 doesn't seem feasible to me. But if you are doing a new build on a stock fuel pump and plan on 550 or more, I'd probably just go straight to a 340.
You have to realize that the dedicated fuel system takes the in tank pump out of the equation completely. If it was making 470whp and you shot a 200 at it, that 200hp worth of nitrous and fuel is using its own dedicated fuel system and doesn't strain the "on motor" pump at all. It could have been even a smaller pump for the stand alone system and been fine.
