Name everything that would cause low fuel pressure
Im going nuts trying to figure this out.
I keep having this low fuel pressure issue.
Im on fuel pump #3. Yeterday I installed the 3rd pump, truck ran great, a day later now is throwing lean bank 1 code.
The last 2 pumps did the same thing, truck runs great for a few days, then CEL comes on, then truck barely runs and fuel pressure will be garbage, like 40@Idle And 25 while driving.
What could cause this
Line sucking shut before pump( in tank too)
Clogged filter
Cheap pump
Too-small pump
Same new pump? What kind of pump? Too small of pump? Perhaps your burning up pumps.
Cheap pump
Too small a cheap pump(Pumping JUST enough but burning itself out doing so}
I had a race hauler do this many years ago, and it turned out the tank had trash in it and kept clogging pumps.
I was thinking the same thing also. It could be your clogging pumps due to trash in the system.
This issue is on my stock 01 silverado with a 4.8
The pumps are from A1 auto and just a direct replacement pump.
I cut a trap door in my bed since the truck is a rust bucket beater. I can see inside the tank pretty good.
Im not gonna say its spotless, but its not that bad.
Restricted User
Do you still have the old ones? You can measure resistance between the pump connectors to help see if the pump itself is failing. I guess without checking a fresh one, you wouldn't have anything to check against though.
Chances are, you're either sucking up trash or its an electrical issue. No way the pump is too small to have low pressure at idle.
Btw, its day 4 of driving the truck back n forth to work and 3 hours of driving to go look at another truck for sale. No issues.
thanks for the tips.
^ok. did a few googling and it looked like in 2004 was when they moved it into the fuel pump assembly. so I imagine you changed the fpr already?
https://www.silveradosierra.com/vort...or-t18146.html
my mechanic said he also checked it out as well so we did not replace it.
Id the fuel pressure starts acting up again that will be the first thing I replace but this is day five now and the truck is running great
