Ls1
Old Aug 17, 2019 | 12:38 PM
Erics10's Avatar
Default Ls1
I have a ls1 engine from a 2000 chevy Silverado..I put it in a S10 pickup...my question is ,why do I have 80lbs of fuel pressure?
Old Aug 17, 2019 | 12:55 PM
1) You do NOT have an LS1. LS1's only came in Corvettes, Camaros, GTO's, and CTS-V's. You either have an LM7 or L59 5.3L cast iron block, or LQ4 6.0 cast iron block.
2) The fuel pressure regulator might be shot.
Old Aug 17, 2019 | 01:04 PM
Erics10's Avatar
I replaced the fuel regulator...did not help
Old Aug 17, 2019 | 04:30 PM
Check the gauge. Where are you checking pressure?
Old Aug 18, 2019 | 07:42 AM
Erics10's Avatar
The pressure was checked at the fuel rail
Old Aug 18, 2019 | 09:42 AM
Do you know if your gauge is accurate? See if you can borrow another one to check against yours.
Old Aug 18, 2019 | 10:43 AM
Erics10's Avatar
It is accurate...I've had two different tests...I also know that my vent line for my fuel tank keeps pushing fuel out..if I loosen my gas cap up it helps
Old Aug 18, 2019 | 08:02 PM
What is the fuel system setup? Which pump, regulator, etc.? Something's goofy somewhere....
Old Aug 18, 2019 | 09:26 PM
01CamaroSSTx's Avatar
Yeah like do you have a fuel return set up? What are you using for a fuel pressure regulator?
Old Aug 19, 2019 | 07:57 AM
JoeNova's Avatar
Restricted User
You haven't given us any info on your fuel setup. Nothing.
Old Aug 19, 2019 | 09:25 AM
Erics10's Avatar
The fuel set up has a supply return for the engine...the fuel pump I bought was for a ls ..I pulled my pump from the tank because it was set up for a 2.8 v6 and replaced just the motor in the fuel pump so it would have the correct amount of pressure
Old Aug 19, 2019 | 09:46 AM
Still nothing. MAKE and capacity of pump, regulator, etc. There's a reason pressure is high.
Old Aug 19, 2019 | 10:25 AM
JoeNova's Avatar
Restricted User
Fuel pumps aren't made for an LS. Unless they bolt to the engine somewhere, and electric pump is an electric pump regardless of the engine.
The regulator determines the fuel pressure, not the pump. You haven't said which regulator, how your return is plumbed, which fuel pump you're using, what size feed/return, how your tank is vented, what fuel filters you're using and where they are placed, whether its 80 PSI just at idle or while driving, or how its behaving when the fuel pressure is high.
"I did an LS swap, fuel pressure is high" isn't enough to go on.
