255 or 340 ???
It had a Racetrinics rxp269 pump in the tank
I can't find this same pump
They offer either a rxp255 or a rxp340
Car made 400 horse to the rear wheels
(with a junk homemade CAI and the transmission not shifting correctly)
Going to replace the CAI and we think the trans is fixed (found 2 wires crossed in the trans harness)
Was thinking about bumping up the cam a little (but I don't know to what)
It has a Comp Cam now: 613/620 lift, 227/235 Dur @ .050 and a 113 Lobe Sep
This is a street toy
Would like to be around 550 @ the rear wheels
Any and all help would be greatly appreciated
Thanks,
Rob
Thanks,
Rob
http://www.ws6project.com/user_stor/...oducts_id=8399
IMO you will also need larger injectors for 550 rwhp. Start will 42's. With a D1 procharger at 8 lbs of boost it made 500 rwhp with the 42's I switched to 60's when I upped the boost with a smaller pulley It made 565 to the rear wheels and was well within range for the duty cycle with the 60's. There's not much difference in price between the 42's and the 60's.
The motor isn't a stock LS
It's a iron block 6.0 that's bored .065
With CNC ported GM L92 heads, intake and LS3 injectors (whatever size that is) with 92 mm throttle body
With 6.125 rods (add the previous mentioned cam)
Forged rods and piston, but stock crank
I do already have the racetronics wiring harness for the fuel pump
https://www.racetronix.biz/p/connect...80-150/rcs-027
Note: years 1999 - 2002 will have the upgraded bulkhead connector in the new harness kit. Year 1998 has the yellow bulkhead connector. The pin size on it are much smaller and are borderline capacity for the 340 (14 amps).
Other changes are 340 does not use stock regulator so the fuel lines have to be rebuilt. The 255 is definitely the easier 'drop in" between the two choices.
https://www.texas-speed.com/p-2358-r...02-f-body.aspx
My last post was a reminder about the bulkhead connector. OP didn't say what year upgraded harness was installed. No doubt there have been changes since 2005.
Note: with the 255 OP won't have to worry about overpowering the stock regulator either. Even so, I would replace it since the original is probably still in the assembly.
I gotta call BS on supporting 600 RWHP naturally aspirated too. More like 600 Hp crank. Mine didn't even make it that far before fuel pressure began to drop.
The label rating of 255 Lph is developed at 40 psi. You've got to look at the flow curve (flow vs. pressure) to see what it does at your desired operating pressure, https://walbrofuelpumps.com/universa...uel-pumps.html
Reading the chart, the GSS 255 Lph pump delivers about 60 gal/hr at 60 psi and 13.5V. Gasoline weighs about 6 lb/gal and the engine uses roughly 0.5 lb/hr per horsepower. Running the math that comes out to 720 Hp. That might be where the idea of supporting 600 RWHP comes from? I don't know, just guessing.
But in the real world there has to be design margin to cover your *** because running lean can cause detonation, and detonation melts metal. It's a risk you can't afford to take. You want to make sure the fuel pump is sufficient in case system voltage drops to battery voltage (alternator output not enough for some reason). That's why Walbro provides you a 12V curve. It's not typical operating condition but sometimes crap happens. That same pump makes only 50 gal/hr at 12V which comes out to around 600 Hp. Okay, so you can safely cover 600 Hp, right? Well.... maybe. Fuel lines and filters cause losses too. And voltage losses in wiring (B+ and ground runs) lower operating voltage across the pump. Results will vary.
If you go up to a 340 Lph pump then be aware the stock F-body filter becomes a notable restriction above 270 Lph flow rate. Lingenfelter bench testing shows C5 filter doesn't flow any better. I put a C5 filter on my car and fuel pressure isn't steady at WOT. One of these days I'll be reworking to a full return line with regulator at the engine. Honestly, Racetronix advised me not to use a C5 filter but I went with internet wisdom instead because it was easier. Don't be me. Do it right.
