Vaporworx fuel controller
I was going to install a turbo, but due to changes of wanting the truck to stay simple and reliable, I am likely going to install a supercharger.
As I have researched, I am thinking of going to modern fuel pump set up as the boyds tank accepts an MU2101 pump which can support 600hp. It can be PWMed via the vapor works controller and upgrade to the zl1 monster pump which would support 700ish horsepower.
I would like a dual zl1 module system, but it appears boyds does not offer than so I am hopeful they are willing to build one off or possibly finding enough c10 guys/gals to do a group buy.
I guess that brings me to the questions... anyone have any issues with their controllers or ideas of a better/more reliable fuel system?
Thanks!
Thanks!
He got me set-up with a dual pump set-up inside a 5th gen Camaro bucket and one of his PWM controllers. This will be going inside a Rick's resto-mod tank in my 1970 GTO 5.3L turbo.
Andrew
Andrew
What size fuel line are you going to use?
My goal is 800ish rwhp so I figured -8 would be sufficient. I assume you aren't running a return and using PWM?
Andrew
Do you have links to the pumps/bucket you're using or how you set it up?(is it in your build thread?)
https://ls1tech.com/forums/conversio...l#post20407874
The inlet and outlet have ORB fittings, but I do not recall the size off the top of my head.
Andrew
Andrew
