Dual intanks or intank/inline, which is better?
Thanks for any advice,
Mike
An internal bosch "big screen" plus an external inline bosch will do ok... Ask DRM... The most foolproof and capable is a sumped tank external..
I got an external inline pump with my ATI tuner kit which I have never used. An Aeromotive A1000. Not sure if that's beefy enough, but if it will help I'll use it. I just want the ideal setup that will be able to grow and support as my car is meaner.
Mike
Mike
What is your realistic projected RWHP?
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Best fuel system for a street car, imo, is a sumped tank and a pair of external 255 LPH walbros. Quiet as hell, OEM reliability, and flow a **** load of fuel. If for some reason you want to make more than 1000-odd RWHP just add a boost-a-pump and you'll be good for even more.
Racetronix stocks dual inlet & outlet high-flow filters and PnP dual in-line wiring harnesses for various GM vehicles.
>WEB SITE<
Just FYI my current setup is a single walbro GSS340, hotwire kit, I run out the top of the tank through stock lines, I then go into a -6AN braided line, small summit -6AN fuel filter, speed inc. fuel rails, the into an Aeromotive boost ref. FPR mounted in the engine bay, the return line is the old supply line. With this setup I'm just not getting the fuel I need.
The things I know I'll do this time is the following:
* Move the fuel pressure gauge sending unit from being mounted on the FPR to right off the fuel rails.
* Run the new fuel supply line all the way into the tank via a bulkhead fitting.
* Get a better, larger fuel filter.
* Increase fuel supply line size.
* Im going to try and move to aeroquip lines and fittings to try and avoid the potent gas smell I have now.
Things I'm still not sure about:
* Do I need to upgrade to an -8AN or -10AN supply line? I'm thinking if I run an external pump, -10AN(or maybe -10AN to the pump and filter and -8AN after that). If I run twin intanks, then probably -8AN.
* Obviously how to setup my pumps?
* Do I need to upgrade my return line?
* I currently have my -6AN tied to the stock lines which have a lot of bends in them to make there way to the engine bay. Would I be better off running my lines in a straighter path?
* I've heard that the bladder on the aeromotive BR-FPR is not the best. Not sure if there's any truth to this. But my problem lies somewhere...
Just to give you guys an idea of some of the questions I'm grappling with. Any help or suggestion is appreciated. Thanks for the suggestions so far.
Mike
-6 Teflon is more than enough to support 800RWHP.
Dual in-tank or in-line Walbro pumps will support your projected HP.
>WEB SITE<
How much? sounds very interesting.
Mike
>WEB SITE<
Mike
This is the same set-up I have, obviuosly I am not going to drop the tank again to take pictures of the sending unit. I would hit up Nasty N8 for pics of the sending unit if he feels comfortable in doing so.
