NastyPerformance Race Fuel Tank
Old Sep 7, 2004 | 02:26 PM
Nasty N8's Avatar
Default NastyPerformance Race Fuel Tank
We are proud to finally offer our F-body Race tank. It has been completely redesigned to offer the best fit and performance available. The tank fits in the stock location without any modifications and holds about 15 gallons. There are several baffles inside the tank to help sloshing and the sender to work perfectly. The sender mount is complelely billet and holds the stock sender in the correct location. The performance sump should clear most exhaust systems and provides 2 outlets for even the most extreme of setups. Can add the pump and filter mounts to the tank as well(as pictured).
Fits 93-98 with some GM parts $60.00
NastyPerformance 93-02 F-Body Race Fuel Tank $499.95 Intro Special $435.00
Add $25 for the pump mounts
https://ls1tech.com/forums/attachmen...chmentid=14002
https://ls1tech.com/forums/attachmen...chmentid=14003
https://ls1tech.com/forums/attachmen...chmentid=14004
https://ls1tech.com/forums/attachmen...chmentid=14005
https://ls1tech.com/forums/attachmen...chmentid=14006
Have a great day Nate
Old Sep 7, 2004 | 07:31 PM
1dirtyZ's Avatar
will the 99 and above sending units fit on the tank?
Old Sep 8, 2004 | 10:57 PM
Time2Kill's Avatar
MASS seller approved
Can you get me a price shipped to 48096
I also want the pump/filter mounts
And do the 99+ sending units fit?
Old Sep 8, 2004 | 11:14 PM
Jammer's Avatar
How is the venting set up...do we need to fill this slower than normal...and tell me about the odor...will the garage smwll or can we add a cannister...lastly if we add a cannister (charcoal), how do we deal w/ boost? Checkball?
Nice tank, Ive been waiting for what...lets just say a long time for your tank to arrive.
Old Sep 8, 2004 | 11:38 PM
1dirtyZ's Avatar
jammer, can you tell me more about the whole charcoal canister situation.
Old Sep 10, 2004 | 01:02 AM
Jammer's Avatar
I cant stand the smell of evapped gas in my garage, the cannister is hooked up to manifold vacuum to "dry" it out when the car is running. However, when you have boost, if no checkball or "something" is installed I think you would be boosting your tank too!
Old Sep 10, 2004 | 12:20 PM
1dirtyZ's Avatar
i see....
now is there a plce to get a fix for this problem or do you know of some one who already did it?
Old Sep 12, 2004 | 11:44 AM
Fast SS on TNT's Avatar
Save me one, I should have the cash next week. I have everything else, just need the tank, with a mount for an Aeromotive Pump. I'll call you monday-tuesday.
Old Sep 13, 2004 | 12:54 PM
Nasty N8's Avatar
They are made for 99+ sending units and they work perfectly. They retain all factory fittings and venting.
Jammer as far as the boost problem you need to use some sort of one way valve like a PCV could work.
Fast SS we have a few left but they are going fast. Hope to here from you.
Thanks Nate
