Fuel Pressure ?
Old Sep 23, 2004 | 03:21 PM
bocksls1's Avatar
Default Fuel Pressure ?
thinking about upgradeing the fuel pump on my Ls1, but I have a few ?s. I know bigger pumps create higher pressures, what does this do to tuning. Does the higher pressure make the car run a little rich or does the fuel system have a pressure regulator to keep a constant pressure at the injectors.
Old Sep 28, 2004 | 02:48 PM
bocksls1's Avatar
anybody know the answer to this?
Old Sep 28, 2004 | 04:11 PM
WillieD's Avatar
There is no tuning required. The FPR keeps it pretty close to normal operating settings.
Old Sep 28, 2004 | 07:28 PM
slow's Avatar
since there is no fuel rail pressure sensor, if you have a higher rail pressure, the computer does not know it, and you will run rich.
However, its normally from 58 to maybe 62 psi, so its not a huge big deal with the ls1's weird fuel system (dropping pressure drop across the injector when you go wot)
Ryan
Old Sep 30, 2004 | 04:35 AM
bocksls1's Avatar
Ryan
Is there a FPR between the pump and the fuel rail?
Old Sep 30, 2004 | 07:51 AM
WillieD's Avatar
yes there is
Old Sep 30, 2004 | 08:48 AM
slow's Avatar
yes, there is a regulator in the tank. It tries to keep a 58 psi pressure, but with a high flow pump, it might push through the regulator and go higher.
Ryan
Old Oct 1, 2004 | 05:05 AM
bocksls1's Avatar
would a aftermarket FPR help keep a more consistent pressure? or would that be a waste of time and money.
