Where to get vacuum for FPR?
However, most people don't install regulators on these motors without FI or big n20 shots.
Ryan
Ryan
If you run a stock (i.e. 97 vette) fpr, then the fuel pressure will be less at idle, and more at wot. That compensates for the vacuum (or lack of it) seen at outlet side of the injector nozzle. Then you have to flatten out the ifr table. (that's if you have the vacuum port hooked up on the fpr...)
Mike
Mike
Ryan
I dont see another line basically that is on this hole in the intake you are talking about that I can tee into.
I know what you mean about getting it setup for a dry kit. I ran a dry kit on the v6, with the stock fpr setup that was on it. (all the way up to a 150 shot)
Mike
