Racetronics Plug and Play Install
Old Mar 28, 2005 | 06:03 PM
2001 Pewter WS6's Avatar
Restricted User
Thumbs up Racetronics Plug and Play Install
Well I had the Racetronics 99+ install kit sitting in my garage. I removed the rearend to get a new set of gears installed so I figured this would be a great time to put the new pump in. Well, this was a very straight foward and easy install. My gas tank was almost empty so it wasn't too hard to drop the tank. I highly recommend this kit. I won't be able to test it out until I get the new motor in but as far as the install goes, this was a breeze...
Old Mar 28, 2005 | 07:09 PM
LawmanSS's Avatar
Hehehe...my install was a breeze, too...right up to the point where I realized that the harness plugs into the top of the fuel module and not into the bulkhead connector on the body...did I mention that I had already reinstalled the tank?!
Old Mar 28, 2005 | 07:46 PM
Restricted User
The tank wasn't that bad to drop. Basically 2 bolts. Kind of sucks having to drop it twice though. I looked at the connector and said I wonder if it fits here. It was right where it was supposed to go. I don't know where all the other connectors go that were in the bag with the extra ground straps.
Old Mar 28, 2005 | 08:47 PM
WS6FirebirdTA00's Avatar
the ground strap is for the battery, and the other hook ups are for an inline pump i believe. install was easy, now i have to make sure the reason my car isnt starting right is because the check valve, which im pretty sure it is, ive droped the tank 2 times so far. 4 hours the first time 2 hours the second, at least it gets easier
Old Mar 28, 2005 | 09:37 PM
ON EDGE WS6's Avatar
It would have been easier if you would have just cut an Access panel..
Old Mar 28, 2005 | 10:16 PM
LawmanSS's Avatar
The packet of extra goodies is for connecting a pump booster...
Old Mar 28, 2005 | 10:43 PM
Floader's Avatar
I just installed the pump part of the kit, wasnt that bad. I was wonderin how you guys routed the wiring harness up to the front of the car, its supposed to go along the fuel lines I guess but mabey there is a better way?
Old Mar 28, 2005 | 10:51 PM
DrkPhx's Avatar
I ran mine alongside the fuel lines through the engine compartment and hooked the positive to the AUX connection. The fuse is mounted adjacent to it on the wheel well.
Old Mar 29, 2005 | 06:37 AM
Restricted User
I ram my wire along the fuel lines the whole way up. I ran it behind the heat shields as well.
