Is there any difference between the racetronix pump and a plain walbro 255?
LS1TECH Sponsor
Originally Posted by Kaneman
Does the MSD utilize the Racetronix wiring harness?
Kane
Kane
If you look at the picture here in our ad you will see the connector for the booster: http://www.racetronix.com/product/RX...99-FPWHG-2.jpg
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Originally Posted by Racetronix
... If you add a BAP as a PNP option to the harness the HP support can be extended as high as 700RWHP. ...
-somebody
LS1TECH Sponsor
Originally Posted by Somebody09
Do you sell this too? I'm definately going to need more fuel than for just 550 RWHP. Also, are you ever gonna finish that rail mounted regulartor?
-somebody
-somebody
__________________
>WEB SITE<
>WEB SITE<
Racetronics or others....I just purchased my racetronics kit w/ hotwire. I am going to be about 650rwhp+ on a 150-175 shout of N20. Will the MSD booster work on a car that is not suppling a boost/vac signal? I want the pump to go to 16V at WOT cuz when the noids open alot of fuel is going by by!
Or do you think the pump and hotwire kit are enough for this HP? With a Walbro 225 on the stock wiring I was getting lean when on the 150 jets at 605rwhp.
LS1TECH Sponsor
MSD unit requires boost.
__________________
>WEB SITE<
>WEB SITE<
For instant-on apps the KB booster is recommended.
Where can one buy a KB unit? Does he have distributers or must you buy direct?
thank you!
LS1TECH Sponsor
So do you recommend it for me and my current RWHP rating being that I will exceed 600? Or is the Hotwire kit sufficent by itself?
Where can one buy a KB unit? Do he have distributers or must you buy direct?
thank you!
thank you!
A list of sponsoring Racetronix dealers is listed on our site.
Racetronix does not distribute the MSD or KB boosters.
KB does sell them retail.
__________________
>WEB SITE<
>WEB SITE<
#32
KB is recommended.
And do I want the 20AMP or 40AMP kit?
http://www.kennebell.net/accessories...boostapump.htm
#33
LS1TECH Sponsor
Is this the right one? Cuz it does mention boost? What will fire this thing off the Hotwire relay?
__________________
>WEB SITE<
>WEB SITE<
#34
The KB unit has two wires which when shorted boost the voltage. They use a pressure switch in their kit to activate the booster. Instead of using the pressure switch you use a relay off of your N2O activation or WOT switch to trigger the KB unit. The power in and out wires on the KB unit have the RX-PBIC connector set installed and plugged into the RX harness. The KB ground wires are attached to the chassis ground. It is a very simple installation with the RX harness.
1 more question, would I need the 20amp or 40amp one?
Thanks again!
#35
LS1TECH Sponsor
Sweet, sounds good!
Thanks again!
Thanks again!
__________________
>WEB SITE<
>WEB SITE<
#36
hey is the pnp harness nessesary or is it just a way to keep the pump workin at the best possible operation and where do you plug it in and does it interfer in the factory wiring harness at all
#37
I installed a Holley 255lph pump in my car and it went right in. Despite what the venders said who tried to sale me a RX pump instead made it sound like I would be making a hack job of my fuel system with the holley. In reality the only modification I had to do was splice two wires going from the fuel pump to the wireing harness. I only paid around $120 and it works great. It was a direct bolt in to me.
#38
LS1TECH Sponsor
__________________
>WEB SITE<
>WEB SITE<
#39
If you don't value what the factory system has to offer then by all means install a generic pump and disable the bucket's functionality. GM engineers put the bucket in there for many good reasons. Truly understanding the fuel system is the only way to appreciate what you have lost.
I installed my Racetronix kit in about 2 hours with my car in the street. I did the trap door method to save time. I know you're supposed to flush the tank, but I'm too lazy to pull the whole thing out. Get the Racetronix kit if you want to do it right the first time.
#40
I ordered a holley fuel pump replacement for my car and it was wrong. Not all the tubes get connected and you have to make your own electrical splice that will have to be placed in the gas......I won't do that. Therefore I am returning the holley fuel pump and I ordered a Racetronix kit Saturday. Hopefully, this kit is as sweet as Racetronix webpage states it is.
