would 87 octane gas hurt the engine??
Old Sep 1, 2005 | 08:57 AM
jlashley2001ss's Avatar
Default would 87 octane gas hurt the engine??
with gas prices going through the roof in NC going for $4.00 gal. im thinking about putting in regular gas. Would this hurt the engine??
Old Sep 1, 2005 | 01:29 PM
ozzykicks2002's Avatar
You have to think of it like this if there is a 20 cent spread between regualar and premium. you are only spending 2-3dollars more on a full tank of gas. Now is it worth it to save 2 3 bucks a tank and make you engine work harder? thats up to you.
Old Sep 1, 2005 | 01:47 PM
jimmyblue's Avatar
Moderator
You will have a lot of short term pinging that will
eventually cause the PCM to pull timing. With a
well controlled coolant temp you could tune for
87, I think these motors are marginal (on the high
side) as far as compression ratio for unleaded but
you could make it work I think.
With 6.0 truck heads this would be more livable
perhaps (lower CR on a LS1 block). But that's not
exactly a money saving activity.
You could fill it up, do a short full-envelope logging
drive, and pull out timing based on the observed
max retard histogram. If you do, it would be interesting
to know how much had to be pulled, where, to get a
no-ping 87 tune.
With the FRA I think you will see wide IAT swings and
this will factor into your timing pullout. Might prefer to
work that angle via the IAT adder table, than the main
spark table but it may take more work to distinguish
the IAT from baseline spark tolerance.
Old Sep 1, 2005 | 02:57 PM
GuitsBoy's Avatar
Maybe it could be simpler than that? If you commit yourself to driving sedately, perhaps the motor wouldnt ping to begin with?
Otherwise jimmyblue is the man when it comes to tuning.
Old Sep 1, 2005 | 04:12 PM
1fastWS6's Avatar
Doubt it....the most likely areas of detonation are in the low rpm + high load areas of the spark table where the timing is real agressive. He might be OK on the stock '01 timing tables but I'm sure mine would NOT be OK in these areas running the '98 timing tables like I am.
Regardless, I think the car would run noticeably worse and wouldn't be worth the hassle for the extra $2-3 per tank.
Old Sep 1, 2005 | 04:20 PM
GuitsBoy's Avatar
Good point.
Old Sep 2, 2005 | 06:44 AM
transam1998's Avatar
Why on earth would you buy a car like this to run 87 octane gas in it?
Old Sep 2, 2005 | 02:48 PM
im not going to run 87 octane i was just wondering if it would hurt it. I strictly use Shell 93 or either Amoco 93
Old Sep 2, 2005 | 03:12 PM
SsZERO's Avatar
Answer: Yes.
Don't use it. Gotta pay to play man!
Old Sep 4, 2005 | 02:42 AM
mattkimsey's Avatar
The owners manual says it's ok to use 87, so it probably wouldn't hurt anything.
Old Sep 4, 2005 | 12:43 PM
My manual says to use 91 or higher or else it will be slow to accelerate. so it wont hurt it but our engines love the good stuff
Old Sep 4, 2005 | 12:47 PM
SsZERO's Avatar
I consider loss of power "hurting". Yeah, you can run 87 if it is the only option, but the LS1 is designed for 91+, and that is what GM recommends.
Old Sep 4, 2005 | 03:17 PM
Doski's Avatar
If you have to use 87 then mix it with 2-3 gallons of e85 and you have a 93 for less money!!!! e85 is 104 octane!!!
Old Sep 4, 2005 | 03:29 PM
mattkimsey's Avatar
Yes, it may "hurt" performance in a sense, but most people(non-enthusiast), if you tell them it's ok to run 87, of course they're gonna do it. For many, 87 may be the best because they don't care about optimal performance, they want to get from point a to point b. So, why spend .20 extra for every gallon if you aren't going to use the added benefits?
Old Sep 4, 2005 | 10:12 PM
SsZERO's Avatar
You want to run the LOWEST octane your engine is designed for for maximum power...if your engine is designed for 87, running anything higher is actually reducing performance. The LS1 is designed with higher compression and works best with 93.
Old Sep 5, 2005 | 02:07 AM
mattkimsey's Avatar
Not debating the "works best with" issue...I agree with that part.
Old Sep 5, 2005 | 03:41 AM
horist's Avatar
^^^ the LS1 will run on lower octane fuel.... stock.. 87 is fine if you never plan on getting on it.. or if it's a rental.... 89 is fine for 90% of the cars
KR is only reported/detected when it occurs...
stock LS1 .... normal driving .... 87 is fine
89 is ok
modified (compression) then 9x is neceassry
if you're stock.... then use 87 octane and don't go WOT..
if you'r emodified and want to go WOT .... get a daily driver
Old Sep 5, 2005 | 09:56 AM
thechef's Avatar
Moderator
i have run 87 several times and have had NO problems but i just drive the car no WOT at all i just drive it EASY and when gas prices are better i get back to 93
Old Sep 5, 2005 | 02:39 PM
slowpoke96z28's Avatar
running 87 octane on a modified car is possible if the driver is prudent about it(ie light throttle at all times)the lighter the throttle, the less likely the engine will detonate. remember, the knock sensor sequence in the PCM only reacts to detonation, it can do anything to stop it before it starts. if yoiu have acces to a tuner, you can pull some timing advance out to prevent detonation, and that will make it easier on our engine, just don't expect the same WOT performance. when you take out timing to stop detonation due to octane tolerance, you lose power.
FWIW, i just suck it up and continue to pay for premium. it would be more trouble/time/cost for me to tune the car for 87 octane and i'm not prudent when it comes to throttle discipline .
Old Sep 5, 2005 | 02:58 PM
BoostedWS7's Avatar
i'm blown so, i gotta run the good stuff....93-94. (Sunoco ultra 94- $3.56 today...ouchy) yuckkkkkk $$$
im thinkin if you are stock and runnin 87, you will be in the low octane timming table, therfore actually be making less power, engine will be working harder,....less miles per gallon it will be producing.
soooo its def not worth using crap gas in these engines made for good gas...i think.
