finished fuel system!
Old Nov 25, 2005 | 08:03 PM
sslow2000's Avatar
Default finished fuel system!
finally finished my fuel system! completely custom from fuel rails to pump. couldn't find a better place to mount the pump and filter, so they're bolted to the bottom of the trunk.
aeromotive a1000 inline pump with filter. can also see super-pimp chrome 12bolt cover and true duals.
didnt like how it was visible from the back at first.. now it's kinda growing on me
and my ratty engine bay. speed inc regulator and fuel rails with 72lb injectors, acceleronics low impedence injector driver, and a crapload of very painful braided line. and i know the engine bay looks like ****, but i'll post it in the appearance section later... half the wire loom is missing in the pic!
Old Nov 25, 2005 | 08:16 PM
monkey11's Avatar
wow nice man, how much did you spend? and by the way what does it sound like??
Old Nov 25, 2005 | 09:49 PM
sslow2000's Avatar
i try not to think about how much i spent...
i think it sounds badass... not really as raspy at all, but loud as all hell.. i love it!
Old Nov 25, 2005 | 10:45 PM
Brandon Boomhauer's Avatar
so are you regulating before the rails, as in feed into regulator then into rails?
or what?
Old Nov 25, 2005 | 11:06 PM
sslow2000's Avatar
i have the fuel feeding to one side of the rails, crossing over, and then goign to the regulator and then back to the tank. i tried to keep most of the lines at the back of the motor...
Old Nov 26, 2005 | 12:29 AM
hrmm
not seeing it honestly.
feeds the passenger rail t's off to the drivers side
and then from the passengerside to regulator?
Old Nov 26, 2005 | 09:17 AM
sslow2000's Avatar
ok, the fuel is fed to the driver side rail and teed off with a crossover so both rails are fed from the back. the passenger side rail has the regulator on it, which regulates both rails and then fuel is passed out of the regulator back behind the motor and back to the tank.
Old Nov 26, 2005 | 12:57 PM
onfire's Avatar
Coal Mining Director
Looks good except you don't have the front driver's side rail hooked up yet.
Old Nov 26, 2005 | 03:30 PM
sslow2000's Avatar
there is nothing connected to the driver side rail... i see now that this is'nt the most effective way to route things.. but... the rail is just fed from the back and relies on pressure from the pump and regulator to keep things happy... either way... its been running great!
Old Nov 26, 2005 | 05:58 PM
why not just run a line from the drivers side rail to the regulator?
I'm just not seeinghow this is working correctly.
Maybe its just the turkey talking to me though
Old Nov 26, 2005 | 07:06 PM
onfire's Avatar
I gotcha now...you ran the feed to the back of the drivers rail and across to the back of the pass rail, through the pass rail and out the regulator to the tank. I'd do what Barandon suggested and loop the front of the driver side rail to the other port that is plugged in the regulator.....the driver side rail is dead headed.
Old Nov 26, 2005 | 10:51 PM
sslow2000's Avatar
i dunno.. i dont see a problem with it.. because theoretically the pressure should be the same all around the driver side rail should be getting all the pressure it needs... there might be a slight pressure drop, but i dont think it'll be big enough to cause the 1/3/5 cylinders to run too lean or anything else of that nature... like i said, it runs great
Old Nov 28, 2005 | 03:00 PM
obZidian's Avatar
why not place the regulator inline before the driver side feed? Im new to this but doesn't a regulator maintain a constant fuel pressure? SO it would seem logical, to me, to have th regulator before the rails?
Old Nov 28, 2005 | 04:41 PM
ddnspider's Avatar
usually a fuel pressure regulator is after the rails.so itll act as a "restriction" to achieve the correct fuel pressure that you want and return the rest.So you have the feed line T'd off the back of the rail and then over to the back of the passanger rail and out the front to the FPR and back to the return?It makes sense to me and as long as it gets the job done why not.what kind of numbers are you making?
Old Nov 28, 2005 | 05:48 PM
sslow2000's Avatar
yup thats what i got going on! no idea on the numbers.. i can't even tune the car yet because i think my hptuners box is broken... can't connect to the car..
Old Nov 28, 2005 | 08:45 PM
ddnspider's Avatar
wow that sucks,why cant u connect?
Old Nov 28, 2005 | 09:07 PM
Jeremiah's Avatar
I think the engine bay looks good.
Have you gotten rid of the ATI by pass valve yet? My charger was being pressurized on the dyno and pushing the oil past the seals, changed to a Tial 50mm and the problem was gone.
Old Nov 28, 2005 | 09:48 PM
sslow2000's Avatar
no i'll probabyl upgrade the bypass later.. i just want to get the stupid thing running first... is that Tial just a bolt in? what's it sound like?
Old Nov 28, 2005 | 10:40 PM
ddnspider's Avatar
i like the bay as well,never been a big fan of wire loom in the engine bay alot myself.
Old Nov 30, 2005 | 07:48 PM
NA$TY-TA's Avatar
I had it on my ATI setup and really i hated it..... its a constant chirping sound.... why because a BOV is not for SC car... its for a Turbo setup.. Bypass is for a SC setup....... the Vortech MOndo works awsome and sounds awsome.......
I have a vid on my site of mine chirping before i took it off.
Kyle
