Racetronix Fuel Pump Install
I'm thinking of using the trap door meathod.
Anyone have any helpful tips on doing this?
Using this meathod, is it still do-able to change out the wiring harness, with the plug & play one that comes with the Racetronix kit??
Just be careful not to cut too deep and get into the tank and lines.
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
Peace
Can anyone give a little guidance as to the exact location of the trap door...I would love to drop the tank, do complete rinse, buy the Racetronix kit and do it right....however, time and money constraints won't allow it. The problem I am having is even after fuel filter replacement, I get plenty of fuel pressure at idle, and steadily drops with more throttle. I just want to at least look at the "from the factory" pump and consider the kit after that. The Best V8 Stories One Small Block at Time
Here's where I found my other answer and a great link to the overall pump replacement:
http://www.public.asu.edu/~nicolasd...umpinstall.html
I see your starting with your winter mods...in prep for the big one.
Dont use the trap door method! I know you dont want to cut up your babby. Drop and remove the tank, so you can clean it out real good. Best way to do it. When i installed mine it was not bad at all.
It can be done just by lowering the exhaust and pulling panhard bar and supprot rod. That was about the worst part. You will need to jack the car to route the wire harness as well.
The most problems that happen when a new pump is installed is the tank never gets a good cleaning, which will lead to nothing but pump problems. Mine has been working great with no problems for the last year.
Have you thought of going with the dual racetronix setup, new item?
Later Chris
Later Chris
Yes, my winter mods are underway, I'm shipping out my intake & TB to TPIS today, on lunch break, to get the 90mmx78mm oval setup!
I also have larger fuel injectors on thier way, and I should probably upgrade the fuel rails since all that is already disconnected right now anyway.
The fuel pump upgrade probably wont go in until mid-summer, or when the stock one fails on me, which even comes first :-)
I'll definetly be re-dynotuning it after all this too, since I didnt bother re-tuning it last year...
So, how are your winter mods going???
- Mike
Doesn't the pump have a filter on it? After all the gas that goes in the tank after you clean the tank out is going to be dirty again.What are you supposed to do keep dropping the tank to clean it out every year? The pump should have a good enough filter to not get clogged up.Its just a modified walbro and thousands of dsm guys throw them in thru the hatch access panels with zero problems aside from the annoying whine they make.
I have seen many cars with access hatches. My dsms have them.They make fuel pump changes very quick and easy. Gm was stupid as hell not to put an access hatch in the car and even if you have a problem you can get to the pump quick with the hatch.
I may pull the tank off my vert to install my racetronix pump but heard the verts are harder to do the access hatch.its an lt1 vert if that matters.
Also where is this twin system on the racetronix site..is it out for 99 ls1 f bodies already?
I am looking for a fuel system shortly for my twin turbo 99.
