Fuel filter never needs replacing?
Old Apr 4, 2006 | 04:33 PM
giant016's Avatar
Default Fuel filter never needs replacing?
I looked in my service manual for my SS and it says the fuel filter never needs to be replaced unless it is causing problems. I've never had a car that didn't call for the fuel filter to be replaced after a certain amount of miles. Is it really good to go without replacing the filter for that long?
Thanks,
Joe
Old Apr 4, 2006 | 04:52 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
No. The dealer usually does them at 40k or so. I do mine every 20k miles. The gas around here is pure garbage.
As an example, we've had 2 cars in this week that filled up at cumberland farms. Both died, and after we went through them, we found ****/water in the gas tank.
Just do it as a pre-cautionary maintenance thing. This will help keep your injectors in good condition and so forth.
They are under $20 bucks to buy anyways, and it takes about 5-10 minutes to swap out.
Old Apr 4, 2006 | 10:08 PM
Juiced2000SS's Avatar
I've never heard of not replacing it either. I would do like said above at the very least 20k. It's too easy not too.
Old Apr 4, 2006 | 10:21 PM
slow's Avatar
I do mine once a year....
Ryan
Old Apr 5, 2006 | 01:51 PM
giant016's Avatar
Thanks, I'll throw a new one in when I change my oil sometime next week. Word for word out of my 2000 F-body service manual:
There is no service interval for fuel filter replacement.
Old Apr 5, 2006 | 02:13 PM
jimmyblue's Avatar
Moderator
Well, yeah, it doesn't need replacing unless it needs
replacing. That's a swell bit of info, thanks, GM. But
since you have no good way of knowing, just put it
on a schedule and have no worries.
Old Apr 6, 2006 | 04:14 PM
algws6's Avatar
03 and above vettes have an interal fuel filter that GM claims it never needs to be replaced. there is a write up on the corvette forum that goes into detail about it.
Old Apr 9, 2006 | 10:18 AM
dame's Avatar
Ryan
X2
Old Apr 9, 2006 | 10:42 AM
Dom's Avatar
Dom
I don't get how it gets clogged though. There is already a filter on the fuel pump. Mine did get clogged once pretty bad so it does happen. I just don't know how anything can get past the fuel pump filter. How fine is the fuel filter itself? I need to crack my old one open.
