Help...ran Out Of Gas...filled Up..still Wont Run
Old 04-16-2006, 12:34 PM
five0killr's Avatar
Default Help...ran Out Of Gas...filled Up..still Wont Run
i ran out of gas the other day as i coasted into the gas station, so i filled up...went to crank it up and it just sputtered....i tried it like 50 times and now it wont even sputter....did i suck up some crap from the bottom of the tank and clog something possibly?
Old 04-16-2006, 12:47 PM
mpe488's Avatar
You might've killed your fuel pump, you might've even done it before you reached the gas station. Mine died on a healthy tank of gas and had pretty much the same symptoms.
Old 04-16-2006, 01:17 PM
five0killr's Avatar
god i hope not....that would suck....i just turned the key forward in the car and hit the fuel valve on the lines by the fuel rail and i got no pressure
Old 04-16-2006, 09:03 PM
madcrazy's Avatar
turn the key on and leave it....you should here a buzz when u turn the key to the on position. if not. time for a new pump.
Old 04-16-2006, 09:21 PM
nitroushane's Avatar
test to make sure you have power to the fuel pump too. could just be a bad fuse from the pump having no gas in it and working too hard.
Old 04-16-2006, 11:43 PM
Moderator
thechef's Avatar
you burned out the fuel pump it is cooled by the gas in the tank when you run it out it over heats and dies
time to upgrade the pump
Old 04-16-2006, 11:50 PM
five0killr's Avatar
yeah, its done for...time for an upgrade i guess. i have true duals, so i dont have exhaust in my way gettin the tank down, and its a 99 so im guessing it will be an easy/self explanitory job
Old 04-17-2006, 12:25 AM
35th SS's Avatar
I agree with the chef.you fried the pump.time to upgrade walbro/racetronic setup.
Old 04-18-2006, 08:47 PM
five0killr's Avatar
so its problem number 2. i put in the walbro, the car cranked right up..and smoothed out after a minute or so, but now its lean as can be..i dont smell fuel at idle, even when the car is cold like i used to and the car is down on power...big time...it feels like im missing 30-40 hp...did i possibly clog my filter..or did the computer or 02's cause something to happen when it went lean and sputtered when running out of gas?
Old 04-18-2006, 09:22 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Lightbulb
BUMMER---I have never,ever,let my tank go below 1/4 ...live and learn man.
Old 04-18-2006, 11:32 PM
five0killr's Avatar
yeah, im learning the hard way
Old 04-19-2006, 07:02 AM
770Guy's Avatar
This exact same thing happened to me, I ended up and pulled I THINK the fuel pump fuse, turned the key, then put the fuse back in and it cranked. It might have even been the PCM fuse or ENG fuse, I dont think it would hurt anything to try all three. Just my .02
Old 04-19-2006, 09:49 AM
markp03's Avatar
what pump did you put in? that seems wierd to go lean after changing to a upgraded pump
Old 04-19-2006, 03:22 PM
five0killr's Avatar
i put in a walbro 255 and i just checked pressure, and its just over 60 on the rail, which is good, and when i tach the crap out of it , and it only drops like 3 or 4 pounds for a split second....so im good on pressure and volume it seems...what could have happened?
