Ethanol Alert! - Be Warned
Now here's where it gets interesting. Ethanol is "chemically charged" to bond with gasoline. This same bond also attracts water molecules. Water is found in all fuel tanks in all fuel stations. That's a fact. When Ethanol bonds with water, it becomes a heavier molecule than gas alone. This heavy water/ethanol molecule then drops to the bottom of the fuel station's tanks. Most pumps at these stations collect from the bottom. If your gas in contaminated you then pump straight water/ethanol into your tank. You will be able to drive about a block before your engine stalls for good. You now have contaminated your fuel system. EXPENSIVE PROBLEM.
Here's the other problem. Say the water/ethanol blend is in very small concentration and thus not populating the entire area around the tank pickup. You now have the problem of excess ethanol at the bottom of the fuel stations tank and not dispersed throughout the gas/ethanol mix. You now pump gas with less octane due to reduced ethanol. You can still drive, but now with 89 to 90 octane vs. 91 to 93.
Many fuel stations have sensors that can detect the amount of water in underground fuel tanks. The problem is that many were never intended to work with Ethanol. The fix is a manual "sticking" of the tank. I'm sure you have seen this and assumed that someone was checking the level of the tank. A long stick with a substance, not unlike brown toothpaste, is lowered into the tank. The brown paste will turn bright yellow wherever it touches water. This is used to manually check the water content in the underground tanks. This should be done prior to and after a fuel truck delivery.
What is your insurance that your station checks? Absolutely none. This is NOT state mandated. This is NOT a law. You must HOPE that your station maintains their tanks properly and checks for water consistently. Think it can't happen at the "big boy's" stations. A Chesapeake, VA SHELL station recently made CNN after they unknowingly pumped numerous customer's fuel tanks full of water.
Not trying to scare you, but these are the facts.
I don't like filling up right after the truck has been there because they stir up all the crap in the tank and it could get into your tank.
right.... as long as they pump mucho fuel then youll be ok
You can test for the percentage of ethanol in your gas by half filling up a glass graduated cylinder with pump gas and noting the level. Fill up the other half with tap water and let it stand. The tap water will fall to the bottom. You will see a distinct line in the cylinder where the water meets the gas. After a while the ethanol will absorb into the water and the line will move up into the cylinder. The amount the line moves is the percentage of ethanol in the fuel.
So I would say you are seriously overreacting here.
Last week after I filled up with the new Ethanol mix I notice two things, first
I started hearing Ignition knock and started seeing Knock retard at my cruise and light accel areas, also I started seeing my LTFT #'s go possitive like it needs more fuel.
My LTFT's always ran -7 to -2 now they are +5 to +8 that’s a big change.
I believe you can tune just fine for the Ethanol but I believe from what I have observed the MPG will suffer and there will be a loss in HP because you will
have to run less Ignition advance and more fuel.
This new Ethanol Mix will cause problems and could destroy a High HP boosted engine if the tune is not changed, like I said I had no KR until I started using the new fuel, FACT.
....you will have to run less Ignition advance and more fuel.
....like I said I had no KR until I started using the new fuel, FACT.
to keep it at the 14.68 AFR in closed loop and the timing advance still needs to be backed down some to keep it out of KR .
I just like my tune right on the money so I am retuning the VE table for a -2 to -5 LTFT.
Keep in mind that this truck was tuned to the max on 93 octane for best
MPG in cruise, so I did have my advance up to the limit just before KR.
So others with a less agressive tune may not see the issuse I have with the Ethanol mix.
I have not started tuning the WOT PE fueling or timing yet, more fuel may fix that but I will start out on the conservitive side on fueling and timing.
http://www.cadillacfaq.com/faq/answe.../veedere10.doc
1. Gas is made of Pentanes (C5H12), hexanes (C6H14), and heptanes (C7H16), plus other additives. Even if water (H2O) did bond with ethanol (C2H5OH) (see below) it wouldn't be heavier than gas, not to mention they are in solution, which keeps the parts of it from "falling out" of solution.
2. If ethanol comes close to water no actual bonding takes places, it dissociates its charge and hydrogen atom into solution just like water does.
3. a big byproduct of combustion reactions is water, so the small amount that manages to find its way into the chamber is not going to be the end of the world.
I wouldn't worry about having 10% ethanol in your gas, yeah it might suck at first b/c you will may have to retune your vehicle, but once you do everything will be back to normal. And yes it will get less gas milage because ethanol has half of the stored energy that gasoline does.
Any questions?
*subscribed*
Josh
