intake Feul Pump change
make sure its not leaking also.
if you got a fuel pressure guage
turn the car ignition on (not start the car)
turn the car off
pressure sure rise to 50+ and hold
if not..u got a leak in the tank from the install
you got a hose leak either the hose connecting to the pump or the same hose connecting to the tank.
which is also probably why you arent getting full pressure..when u initialize the pump the gas escaping and cant build full pressure..and since the line is pressurize...if there is a leak...the gas will escape.
turn the car off
