fuel line picture?
Old Jul 12, 2006 | 12:31 PM
mattsls1's Avatar
Default fuel line picture?
Anybody have a pic of where the fuel lines go on a fbody? There are 3 lines that come from the pump. My middle line doesn't have a connector. Anyone know where I can pick up an extra?
Old Jul 12, 2006 | 02:39 PM
mattsls1's Avatar
here is my tank
Old Jul 12, 2006 | 04:31 PM
mattsls1's Avatar
you're telling me nobody knows what lines go to what?
Old Jul 12, 2006 | 04:48 PM
1LoudTA's Avatar
replace it all with 10AN steel braded
Old Jul 12, 2006 | 06:11 PM
DWillTA's Avatar
The long plastic line with the white quick disconnect goes to the Fuel filter and is labeled F on top of the fuel module for FEED.
The short plastic line with the white quick disconnect goes to the Return line off the T block.
The black plastic line with no white disconnect just a black end is the EVAP line and goes to the only other line available.
Hope that helps
Dave
Old Jul 12, 2006 | 06:15 PM
DWillTA's Avatar
Just saw your pic.
Curled line - Center outlet
Long Line w/ white disconnect - F marked outlet on module (Right in pic)
Short Line - R marked outlet (Left in pic)
Dave
Old Jul 12, 2006 | 06:16 PM
DWillTA's Avatar
Also the center line DOES NOT need a quick disconnector.
Old Jul 13, 2006 | 12:42 PM
mattsls1's Avatar
Thank you
Old Jul 13, 2006 | 05:52 PM
DWillTA's Avatar
Not a problem. I just did the install of my Racetronix PnP. The stock pump at 69,000 miles was very weak after seeing what the racetronix pump can do.
Old Jul 16, 2006 | 10:47 PM
MiaSSmaro98's Avatar
cool info but if u wanna run a new return style system u have to remove the intank regulator can u post pics of that
