Vacuum modulated FP or static?
current stock system is vacuum modulated.
at idle and low cruz pressure is 42-43. then climbs to 48-49 at wot via vacuum (map to regulator)
i pulled the vacuum line off the regulator and pressure goes static. solid 50lbs.
and at wot 6300rpm it still shows 49+ - 50.
would there be any disadvantages to leaving it static at 50lb?
(02 v6 fbody with walbro intank)
(hptuners so retuning trims is no biggy)
thanks
thanks
good one bro.
couple of more weeks and i'll be heading your way. gauranteed!
You still needing that S pipe made?
made an s pipe in the garage, but i do have some other stuff that i would like to have you handle. just need a couple of weeks to clean up my $$ situation.
got any input on whether or not i should just leave the fp static at 50?
i have a used vortech 50/70 inline that im considering adding to the system to help out.
after reading your comments on the inline pump installs your the man for the job...hehehehe
i'll get with ya as soon as my bank clears my funds....stupid BofA..
new walbro intank that works fine.
im on my 3rd injector swap in a month.
looks like im just gonna throw in the towel and find some 60lb'ers and be done with it.
btw. met david yesterday, got the DS. kewl!
really would like to see his ride at the track. sounds impressive.
thanks again,
dan
thanks again,
dan
But nonetheless, Stage 1 heads with that small cam, its makes killer average power. We will have new numbers here soon in the next 2 weeks or so.
btw, got and 42#'ers laying around. im in need of 6..
