Post up your external fuel pump systems & tank mods
Post pictures of your aftermarket preferably external fuel pump setups with a modified stock plastic gas tank.
Lets see some sweet setups.
Originally Posted by Nasty N8
What info you need? I can set up any system you need.
Nate
Nate
-B
Our stage 3 street kit uses Lonnies pumps I can set you up with the rest of the system to finish it off. Complete lines, MagnaFuel regulator and filter, rails and all fittings and hardware needed to do the install.
Nate
Nate
I dont even like how far away mine is, I went with a 12 an feed line to the pump just since its so long, I didnt know where else to mount mine when I did it the pumps are huge.
Senior Member
Yes, try to keep the pump gravity feed and with as big of a line as possible. I had my pump infront of the axle and the pump had to pull fuel from the tank over the axle and to the pump... it didnt like that. The can push like hell but the dont pull very well.
