IAT sensor and Fuel rail question
1st, I assume that the PCM requires the IAT. Given that assumption, and given the fact that I won't be using a SS air box with the OE IAT, does anyone have any suggestions on an after market IAT that plugs into the GM harness, or is it ok to use a generic bosch IAT and splice the bosch connector to the GM harness.
2nd, the 944 uses a return type fuel rail system, the LS1 not. I have an adjustable FPR because of the mods to the turbo engine. Will a fuel rail from a 97 corvette, camaro, etc that is a return type fit on the LS1??
Thanks in advance for the input.
http://www.diyautotune.com/catalog/s...58fb2b7dd276ac
That's on the car in my sig, so it should work on anything you are trying to do.
As for the fuel rails...the 97 Vette rails are a return style rail, and should also work for you. The 97 Vette was an LS1 - but the 97 F-body was not. The Camaros/Firebirds didn't come out with the LS1 until 1998.
http://cgi.ebay.com/ebaymotors/ws/eB...2595&rd=1&rd=1
would line up with the injectors on the LS1
