Pics of my Dual Walbro GSS340 Intank Mod
Moderator
I put the post in the FI section where we discuss the issue of lack of fuel quite often:
https://ls1tech.com/threads/showflat...65&fpart=1
!Dial-up Director
Re: Pics of my Dual Walbro GSS340 Intank Mod
Hard to tell from the pics but what did you use to y the pumps together?
I would run a 8AN braided line and Y it to each rail then y it back out the front of the rails to a regulator.
Justin
Justin
Moderator
Thanks for the advice.
I used a Tee.
Instead of going into the Tee like this:
<font class="small">Code:</font><hr /><pre>
</pre><hr />
I went in like this:
</pre><hr />
It made more room and at least one of the pumps gets a straighter shot.
The size of the line DEFINITELY makes a difference (per your advice).
I first coudn't find the size Tee I ended up using and there was a BIG difference in how much fuel pressure I maintained with less restriction.
There's definitely more that can be gotten out of this setup.
I used a Tee.
</pre><hr />
</pre><hr />
Ah, you mean one of these!
I have the Racetronix 340 setup, but when the stroker is done. This baby is going in. Or I may go with a sump and a big aeromotive pump.
BlackLS1T/A- I read in one of your posts you were looking for fuel rails. One of our sponsors (Speed Inc) sells high flow billet fuel rails for a pretty good price. Might be easier than modifying 5.0 rails. Take it easy.
Justin
Justin
Moderator
We have high flow fuel rails that are a direct bolt on.
Nate
Nate
