?? flat-lined flow table, now L&S trims Zero!
The ATAP data is screwy - the long term and short terms are 0.00 and never move, WTF? And the techedge a/f meter is reading 12.5 or so most of the time under part throttle - thought it s/b close to 14.7.
it's almost as if the fuel trimming has been suspended. Any ideas as to what is happening? Gues the next step is to try to back out the fuel flow table changes and see if the it once agin has dynamic ltrim values.
souds like you are in pe all the time or the car didnt go into closed loop.
i run the 5.51 with a referenced regulator no problems.. i would look elsewhere first...
oh btw set your base fuel pressure (no vaccum/no boost position) to 50psi to start.
Did you find 58lbs delivered too much fuel or made it more difficult to tune? Just curious why 50lbs.
anyhow if your ltrims are 0 something is telling the computer that you are in power enrichment OR open loop when you shouldnt be... nothing to do with injector flowrate.. but hey put it back and see if it goes away..maybe
no codes, not getting an SES on the front sensors, but did have the pass. side front sensor disconnected, something to check. will also see if I fat fingered a code when turning off rear sensors.
your computer didnt go into closed loop because there was no o2 sensor to read for it to come out of open loop.
