Dropping fuel pressure Help
I did check the volts and they are 18.3 and when the rpms rise under wot (boost) they go up to 18.9 I have not touched anything on the boost a pump. Its hidden.
Any suggestions where to look or what to do? Is the Walbro going out?
1. Change the fuel filter and see what happens.
2. Check the pump and make sure the fuel line is not split at the pump...possibly change the inlet sock now since you'tr there.
3. Get a new pump if 1 and 2 don't fix it.
