fuel pressure gauge
Old Oct 23, 2007 | 08:25 PM
cherryelky305's Avatar
Default fuel pressure gauge
Im looking for some pics of people running small fuel pressure gauges on their stock LS1 fuel rails, on the schrader valve. Is it true that stress fractures will occur?
Old Oct 24, 2007 | 10:21 AM
tennz28's Avatar
Ive had a Jegs FPG on my rail for about 2 months now with no problems. If you use the gauge adapter from casper electronics (sponser) the gauge sits very close to the rail. But ive seen people go to AZ or some parts store a get 3 different fittings to connect it all. Going that route will cause your gauge to sit about 2 inches from the rail and it that case I would be worried about fractures. Hope that helps
Old Oct 24, 2007 | 10:54 AM
Thanks, I'm gonna check out that sponsor, see if i can find the adaptor.
Old Oct 24, 2007 | 11:18 AM
Black2001z06's Avatar
I have a brand new one from Casper, if you need it.
I'll take $10 plus shipping and will take a MO or Cashier's check.
I'm an honest seller and will ship as soon as the funds clear.
I can take a picture if need be.
Shoot me a PM if you want it.
Thanks,
Old Oct 24, 2007 | 11:42 AM
DAMNIT!......just placed my order with casper. I just checked back to late.
Old Oct 24, 2007 | 09:14 PM
SSsuperdave's Avatar
what was the part no. @ Casper. I can't find it.
Old Oct 24, 2007 | 09:19 PM
107133, i searched for adapters on their site and i had to scan through all the wiring stuff, but its there. Fuel rail adapter. $12
Old Oct 24, 2007 | 09:20 PM
thanks dude!
Old Oct 25, 2007 | 02:09 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
I used an adapter plus a short length of 1/8 pipe + right angle fitting with my FPG (to clear FRC's) has been installed for 4 years now with absolutely no problems - we're talkin ounces here, not pounds stress fractures should be no problem
Old Oct 28, 2007 | 03:32 PM
planemech2's Avatar
Will the Jeg's gauge screw staight into the rail? The Casper adapter goes on the Schrader valve itself.
Old Oct 28, 2007 | 03:40 PM
no no no. The jegs gauge screwes onto the casper adapter, then you screw the whole thing onto the threads that the end cap screw onto. You have have remove the schrader valve by unscrewing it like you would a car tire.
