H/C Nitrous fuel system help
I have had a Racetronix Pump on the car for almost 2 years now. I think there may be a possibility that it could be getting weak causing the drop. I am running 42 pound injectors.
I am thinking about going to a return style system, but i don't really know how i need to go about this. I would like to have the regulator in the engine bay for easy ajustments.
Give me some suggestions on what I need to do. What size feed line do I need to run? How does a return system work with a variable voltage pump?
What all is involved with running a return.......do I have to drill into my fuel tank.
I really don't know where to start. Any help would be appreciated.
Thanks,
Brent
You can probably see by now that I am a newb when it comes to the fuel system.
Thanks for the help
Nate
I am starting to think something is wrong with the pump that I have now. Everyone says that the racetronix pump and 42 lb injectors should be good up to 600 at the wheels. Is my pump getting weak or did I not do something right when I put it in?
My fuel pressure drops to 55-56 on motor. It shouldn't be dropping that much on motor should it?
I think I am going to pull the tank and check to make sure that I didn't screw up the little flex tube.
Thanks everyone
On the dyno it stayed at a consistant 12.5 af on motor and 11.8 on nitrous.
It did stumble a little bit on a motor pull in the high rpm range. Not sure what that was all about. That is the first time that it has done that. When it stumbled the af shot up to 14.6 for a second and then went back to 12.5.
Wonder if the fuel pump could cause this to happen. I have went wot a couple times after that and it hasn't done it since
