Problems w/ running twin pumps simultaneously?
Old Mar 7, 2008 | 07:45 PM
Whistler's Avatar
Sawzall and Welder Mod
Default Problems w/ running twin pumps simultaneously?
I know the norm is the hobbs switch or nitrous arming switch, but has anyone had a problem with running a pair of Walbros full time?
Old Mar 7, 2008 | 08:38 PM
code4's Avatar
Check this thread out.
https://ls1tech.com/forums/showthrea...869&highlight=
Old Mar 7, 2008 | 09:44 PM
Whistler's Avatar
Thanks. I searched but that didnt come up
Old Mar 16, 2008 | 05:36 PM
stevieturbo's Avatar
No reason why not.
Im using a pair of 044's all the time.
Old Mar 16, 2008 | 06:48 PM
onfire's Avatar
Coal Mining Director
People do but I would not since it heats the fuel up...I ran twin 044's all the time and at 58psi, the gas tank was warm to the touch. Easy to install a Hobbs switch (I did) and just run one and let boost turn the other one on.
Old Mar 16, 2008 | 06:52 PM
And have you monitored temps, to see if there is any difference running 2 pumps, or one ??
I was running 66psi base before, and yes the tank did get warm to the touch. Certainly not hot by any means though.
I will be monitoring actual temps when I get my car going again. Just out of curiosity.
Old Mar 16, 2008 | 06:58 PM
Whistler's Avatar
I have both pumps in the tank, but only one running currently. I'll try a test to see the temperature delta running the secong pump full time.
Old Mar 16, 2008 | 10:41 PM
onfire's Avatar
The "hando meter" said at race fuel levels (3 gallons or so) it was getting too hot for me.....may never cause a problem...especially with a full tank to heat up....but too easy for me to install a hobbs switch with a shunt for the track.
