car keeps loading up and backfiring?
Old Mar 16, 2008 | 04:22 PM
h.o.ls1's Avatar
Default car keeps loading up and backfiring?
well i have a 98 camaro with the ms4 cam and some bolt ons..any way it just started like loading up everytime i go to get on it just a lil bit it cuts out then will go then will cut fuel it feels like and backfire then die then ill restart it and its good to go and will do it right away again? ive already checked the maf. its got fuel pressure and i swapped injectors but its still doing it....WTF!!!!!!
any help would be great!
Old Mar 16, 2008 | 11:14 PM
QuickdomesticRacer's Avatar
I'm also having similar problems. But mine doesn't stall, just runs very poor. ttt
Old Mar 17, 2008 | 06:26 AM
VH5150's Avatar
Dynojet Fan
Its probably the tune
Old Mar 17, 2008 | 08:17 PM
h.o.ls1's Avatar
its been fine for the last year..what would make it turn all the sudden?
Old Mar 17, 2008 | 10:30 PM
BenLaz's Avatar
check the wiring running to the crank position sensor... it might be burning/shorting out against your headers
Old Mar 17, 2008 | 11:39 PM
h.o.ls1's Avatar
ok ill do that
Old Mar 19, 2008 | 12:08 AM
Thanks for that as well. I'll try that.
Old Mar 19, 2008 | 06:40 PM
h.o.ls1's Avatar
nope no burning wires
Old Mar 19, 2008 | 09:03 PM
BenLaz's Avatar
hmmm your problem sounded exactly like how my car was acting.. and it turned out the wires going to my crank position sensor were burned thru from resting on the header primary... probably causing the timing to get all effed up! which would explain the loading up and back firing..
Old Mar 20, 2008 | 12:42 AM
Damn. Alot of checking.
I read somewhere it could also be faulty injectors, bad coils, o2 sensor, MAF, TPS, broke valve and/or valve spring?
Old Mar 30, 2008 | 09:26 PM
h.o.ls1's Avatar
well im assuming its a broke spring since everything else has been changed ...i just dont see how i could have broke a dual spring running with the cam that i have...
Old Mar 30, 2008 | 11:58 PM
I had a major vacuum leak. fixed that. Ran fine for about 20 miles, then symptoms came back. GM's tech2 said Vacuum leaks, and possibly O2 Sensors..
Old Apr 6, 2008 | 05:33 PM
Oso SS's Avatar
kind of obvious but have you checked your spark plugs and wires?
Old Apr 7, 2008 | 09:00 AM
Old Geezer's Avatar
Scanned it?
Old Aug 3, 2008 | 06:49 AM
lemons12's Avatar
i also have an ms4.. and see this problem a lot.. i have the same problem but mine just loads up between 2k-3k rpms and stops EXACTLY at 3k rpms.. will do it for about 5 mins when it gets warm.. then will stop.. turn it off and turn it back on it will do it again...
also, i normally idle around 1500 rpms.. its supposed to be at 1000rpms no matter what... thats what the tune is for at least.. everyonce in a while it will go to 1000 but thats rarely.. if i put it in park it revs up to about 2k rpms then goes back down to about 1300..
Old Aug 3, 2008 | 07:28 AM
Old Geezer's Avatar
Question ???
Originally Posted by Old Geezer
Scanned it?
Well, have you?
Looks as tho you have checked some items, replaced the injs, and there's still no scan done??
Old Aug 3, 2008 | 09:05 AM
linegtdt52's Avatar
Default Wow!
You really opened pandora's box but you need a scanner to tell you first if you are throwing anything. Second you need one to log your tables so you can see map response and tps resonse. I havent seen it but maybe your TPS sensor is running out of range because it's shot. You map sensor could be shot as well but if it was shot it wouldn't idle below 2000. GET THE SCANNER
Old Aug 3, 2008 | 09:07 AM
linegtdt52's Avatar
Still also sounds like O2 sensor, good luck
