Hydrogen Kit questions
Show us the proof.. If its a pat. it will be easy to find, and include all the details needed to make your own....
The myth of a 100 or 200 mpg carb has been around since the 1950's......
Heres the proof. I haven't been on the site in a while.
http://www.rexresearch.com/pogue/1pogue.htm
I guess it wasn't a waste of bandwith.
edit-- Yes I did call someone a ******* idiot. Now I just need to figure out how to implement a physics class filter for tech forums.
Are you a complete ******* idiot? Patents have also been issued for perpetual motion machines. This has ABSOLUTELY no bearing on whether or not they worked (none did). BTW mods, I asked a question, I didn't call someone a name.
you just found a solution to all of the worlds energy needs
Theres a college thats been doing hydrogen conversions for a while now. If you look on youtube, you can find all kinds of info about it. They were running it off of multiple fuels and their hydrogen was in a tank. The videos are a bit boring but real informative. Hydrogen isnt lower in octane, it just burns much faster. Octane and burn rate arent directly related. Introducing hydrogen as a supplemental accelerant allows for more rotational energy because the piston is closer to TDC when the fuel is ignited. In an engine with 35deg. of timing, the piston hasnt reached TDC yet and the rotating assem. is fighting increasing pressure BEFORE it begins the power stroke. The other benefit from hydrogen is that it causes the primary fuel to burn more completely, i.e. cleaner. I have no idea if these water generators are the answer, but hydrogen def. has benefits that have been proven. Almost forgot to mention BTW, the colleges hydrogen car had a timing adjusting box installed so they could adjust on the fly acording to what fuel they were running.
#33
ford has some v-10 hydogen vans they are experimenting with as is honda in calif.
brown's gas works but there are down sides. it is cororsive in higher levels no timing btdc
rings and cylinders rust up. safety issues etc...
you could run a later model car with it in open loop.
here's a good place to start
waterpoweredcar.com hydrogen booster is a good one to put in google that will get you hours of reading time.
after reading a members claim on a tuner forum of 33mph on a '99 350ci vortec suburban i spent the afternoon reading. when i got done reading i think that his claim of almost twice the mpg is very possible and most likely true. the down side is big though.
#34
#35
theres a guy that came by my shop today to have a 40 amp home made one cleaned up for his truck. he already has a small 15 amp one on his BUG and saw 100 mpg more per tank. ill be building one shortly for my 82 impala that now gets around 12 mpg
