Racetronix 255 pump limits
I stock the Racetronix kits.
If you need a bigger fuel system, I can also get you what you need for your setup.
Trying to get a 50+% increase with a voltage booster is pushing things. At 800rwhp, you need corresponding fuel system mods as well.
Are the other mods you're talking about things like larger feed line, fuel rails & injectors, or are there other things? Of course, by the time you have anything like 800hp you'd want to be using a huge gauge wire for pump power directly from the alternator, right?
So.....ummm....my UNcorrected numbers are maybe +or- 30, whats your point? Lonnie just said 550rwhp can be reached with a 255 on a power adder car, so I add a boost-a-pump and now I'm a liar?
I guess God loves me, obviously not you
550rwhp on E85 would be roughly equivalent to 720rwhp on gas, so this requires quite a bit of fuel. This is a lot, even with a pump booster. It is entirely possible, but what I consider on the ragged edge of safety.
No juice, I am guessing you are running a large injector with a lowered base pressure?
