When does more fuel pressure need tuning?
Old Jun 5, 2008 | 08:44 PM
9000th01ss's Avatar
Default When does more fuel pressure need tuning?
I have a Racetronics pump and wiring kit in my car.
The engine is stock.
It gets from 64 to 61 psi at the rail at idle.
It also seems to run rich, the LTFT's never go positive.
They average 0 to -14 and the STFT's I've seen at +5 to -43
At what psi increase do you need to adjust the tune?
Old Jun 5, 2008 | 09:02 PM
otherwhitemeat's Avatar
Any change in fuel pressure can make a massive change it tune.....in other words put it back to where it was.....one of the only reasons to change fuel pressure is to compensate for injector cycle duty and from the sounds of it you are not able to change your own tune so make sure it is at the stock setting till someone can tune it for you......and that would explain your rich condition too...
Old Jun 5, 2008 | 09:25 PM
9000th01ss's Avatar
I can tune it, I've had HPTuners since 2004.
See heres the problem, I've asked this question several times.
I got the car as a roller and it had the pump. I said I was going to take it out and Racetronics got on here and said thats a dumb idea, it'll work fine with a stock engine and stock tune.
There is no adjusting it, it's meant to replace the stock fuel pump and thats it, no other regulator required. According to racetronics no tuning required. The benefit is that it gets increased voltage with the wiring harness and it can be hooked up to a MSD box to increase the voltage to increase pump output for nitrous use.
According to other people here it's like one third says tune and two thirds says not.
I've been posting the question asking why my LTFT's are never positive and so far every reply I get is the opposite of the other so I have no idea what to do.
If tuning is the answer do I tune IFR? or VE and MAF? or all or neither.
I've spent literally all day searching this and can't find anything, one site says do this and the other says don't, etc.
It seems like something that would be common knowledge yet I can't find a straight answer.
I can't back down on fuel pressure so what do I do with the tune?
Old Jun 5, 2008 | 09:31 PM
9000th01ss's Avatar
I have been helped by one guy in the PCM forum and he said make the numbers bigger in the IFR table. He gave me specific numbers. It seems like that would make it more rich. Been waiting for him to get back to me on that. I haven't had a chance to put it in a tune yet.
To make it lean with higher FP do I make the IFR numbers higher or lower?
Old Jun 6, 2008 | 01:11 AM
wow..that sux. I'm used to tuning on a F.A.S.T. unit.....so not sure which way the #'s should go... anyway your LTFT ideally should be close to zero...that means your ECU isn't seeing a reason to add fuel all the time.....and your STFT is probably ok adding or pulling 5-20%.....which it might be doing now at idle or WOT. Do know that some ECU will relearn the LTFT and put your car in a different part of the map.....may have to disconnect power to reset???? not sure??? so how much of a % is your LTFT pulling? and what about the short term fuel trim "STFT", what is it doing?
Old Jun 6, 2008 | 06:53 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Welp...here's the problem. The PCM has no way of monitoring or knowing what your fuel pressure is. You are above the base 58 psi operating pressure, and are seeing the reasonable effects of that.
Adjusting your IFR table is the correct way to go here...you just need to make sure it shows the right flow rate based on 61-64 psi (you'll have to pick a value in there) instead of the stock 58 psi.
Racetronix, in this case, is wrong...any difference in fuel pressure from stock can't be monitored, and will cause you to run rich. It's just how the system works...and Racetronix pumps installed with the stock, in-tank regulator are known to cause a pressure increase at the rails.
Old Jun 6, 2008 | 07:43 AM
9000th01ss's Avatar
in my first post
Old Jun 6, 2008 | 08:09 AM
9000th01ss's Avatar
From HPTuners.
Originally Posted by WS6FirebirdTA00
whats wrong with the fuel pressure, that is normal for these cars. If you have stock injectors, then that is fine as well.
From here
Originally Posted by khaos288
you're fine, nothings gonna blow up and spill gas everywhere and catch on fire
Originally Posted by 2K1WS6TA
+1. My car has 68lbs of fuel pressure at the rails.
Originally Posted by crewchef
Have you done any actual tuning or just logged what it's doing? With higher fuel pressure the injectors are probably putting out more fuel than what's being commanded. I've never dealt w/ higher fuel pressure on stock injectors but assume you might have to scale the IFR table w/ new values. VE and MAF tables are the other basic starting points.
Originally Posted by mcfarlnd
have the ve and maf tables been tuned yet?
Originally Posted by 69LT1Bird
What are you using to regulate the fuel pressure? I am not sure why you would want to run that much fuel pressure on stock injectors and a basically stock engine. Set the pressure to 58psi and see what it does. Do the basics things first. Remember Air, Fuel, Spark.
The pressure should be that big of a deal, did you change the IFR table in HP Tuners to match the stock injector to 64 psi pressure? You may want to do that, than the injector pulse width should be closer which should help.
I think you have 24lb injectors stock, correct? If so, here is what the numbers look like for 64psi.
Injector Flow (lb/hr) 25.21127971 25.35371501 25.49535458 25.6362116 25.77629891 25.91562899 26.05421398 26.19206571 26.32919571 26.46561518 26.60133506 26.73636601 26.8707184 27.00440238 27.13742781 27.26980433 27.40154135
Use these. Your stock injectors are 28 lb.
Injector Flow (lb/hr) 29.41315966 29.57933418 29.74458034 29.90891354 30.07234873 30.23490049 30.39658298 30.55741 30.71739499 30.87655104 31.0348909 31.19242701 31.34917147 31.50513611 31.66033244 31.81477172 31.96846491
Originally Posted by Goldfinger911
More fuel pressure + No retune = Worse mileage
At least check your fuel pressure at the rail and adjust your IFR table accordingly. If all you have done is put in the Racetronix pump, then I bet your fuel pressure is close to 62-63psi at the rail at idle.
Originally Posted by z28_theantirice
If you are running stock injectors and fuel pressure regulator there is nothing to tune for. Make sure your FPR is in good working order...
Originally Posted by OreoLt1
"z28_theantirice" is correct if you haven't changed the FR or the FPR the pressure and volume is increased to the rail but past the rail everything still the same per inj. pulse and psi.
I installed a Racetronix kit and gained Mpg's by 3-5 with a new tune!
I guess it's time to shut the computer off and consider the internet and forums useless. What am I supposed to do with all this conflicting info?
Old Jun 6, 2008 | 02:19 PM
odd boy's Avatar
Cool down boss,
In theory, when the pressure increases the flow rate of an injector will increase too. Therefore, it should be tuned. Let's have a simple i.e:
42 lb/hr Injector rated at 43.5 psi gives 48.49 lb/hr at the rail pressure of 58 psi,
If we increase the pressure to 60psi the injector will give 49.33lb/hr,
If we keep increasing the pressure to 70 psi the injector will give 53.27 lb/hr.
So in conclusion : tune makes things work right, but it won't be that necessary for very very minor change. Similarly, minor pressure change won't make big big change in L/STFT.
I think ur problem is not with the pressure the change in pressure is minor, the problem could be something else like O2 sensor needs to be replaced,...etc
Old Jun 6, 2008 | 04:14 PM
MeentSS02's Avatar
The above is correct, but I'm not sure what constitutes a minor pressure change versus a major one. Getting the tune back in line through the IFR table is a start, but as mentioned, it could be caused by other factors as well. Start with adjusting the IFR table, and see where that leaves you.
Old Jun 6, 2008 | 09:24 PM
9000th01ss's Avatar
So you're saying adjust the IFR table for the fuel pressure I have now. If that puts things in line I'm ok, if not then look into component problems? (sensors, etc)
I just don't want to cover up a failing maf or O2 by trying to tune it.
Old Jun 7, 2008 | 01:02 PM
odd boy's Avatar
9000th01ss,
I did quick calc for you. When u look at it u will find that the difference is around 10%, which isn't a minor change. I think u can go with the tune part. I am really keen to see ur result.
File Type: doc
Old Jun 7, 2008 | 03:14 PM
9000th01ss's Avatar
Originally Posted by odd boy
9000th01ss,
I appreciate your efforts.
There seems to be a problem with the old numbers, I guess you added 10% to what you have listed as old numbers, but I don't know where you got those old numbers from, they are not mine.
These are my numbers 28.70851 28.89453 29.08055 29.26656 29.45258 29.57659 29.76260 29.94862 30.13464 30.25865 30.44466 30.63068 30.81670 30.94071 31.12672 31.31274 31.43675
Old Jun 8, 2008 | 02:19 PM
odd boy's Avatar
I got them from a Camaro 99' "stock car", I didn't add 10%, I calculated the flow rate of stock injectors but with a real pressure equal to 64 psig. I revised it for you and the diff came down!!!!!!
File Type: doc
Old Jun 8, 2008 | 04:20 PM
9000th01ss's Avatar
Well Thanks, I'll give it a shot.
I'm really leaning towards a component failure at this point. (or starting to fail)
I have the same problem posted on HPTuners site and it was pointed out that there is no reason (tune wise or FP wise) that my stft's dipped to -43 for a few seconds during one run I was logging.
This guy on HPTuners site could probably tell me where to look, but he just can't type more than two sentences at a time so theres that. He said it might be an O2 going or something else.
Old Jun 9, 2008 | 08:02 AM
Old Geezer's Avatar
Do we know for sure, that the pressure gauge is correct? [If not, then just maybe there is some other problem??]
I test the small, rail mtd gauges against the master gauge on my inj bench.. Some are as much as 7psi off. Recently, i've tested only 2, that were within 1 psi...
Old Jun 9, 2008 | 08:35 AM
9000th01ss's Avatar
I am an HVAC/R tech. A gauge set for testing freon plugs right into the fuel rail, but instead of contaminating my whole gauge set I've taken a 1/8 npt female to 1/4 flare adapter and used it on a spare gauge. I have literally 15+ gauges for measuring not only gas but liquid as well.
And when I plug my FP tester into my other car with the stock pump it reads dead on 58 psi.
I've even tee'd several gauges together to get a comparison and they are all close. They also have a zero adjustment to bring them back to 0.
Old Jun 9, 2008 | 11:25 AM
odd boy's Avatar
Just to prove that the problem is not with pump/injectors, run the car on open loop and see what BEN's you will get. If they are okay, that means the tune should be okay too in the CL.
Old Jun 9, 2008 | 11:51 AM
9000th01ss's Avatar
Well from what I gather the fuel trims swinging from 0 to-14 is just the VCM doing it's job (despite the several, possibly hundred of write ups I've read that say they should swing ideally +/-4)
I'm starting to think there is a problem other than FP, I get occasional dips in the stft down to -43 and it's not DFCO, the pro on hpt's board just says that could be a problem elsewhere *i'm just not going to tell you why i think that or where to start looking or anything*
I guess my post count on that forum is too low or something.
What does BEN stand for? I looked on here, google, hpt acronyms list....
Old Jun 9, 2008 | 12:25 PM
odd boy's Avatar
This is what we use in efilive which is the actual AFR/commanded AFR, so it is the correction factor. hp tuners call it AFR error (table no 7).
