Best 60' on 2.73 gears?
Old 09-16-2003, 08:56 PM
gillbot's Avatar
Default Best 60' on 2.73 gears?
What's the best 60' that was attained on 2.73 gears? I'm just trying to compare my lowly 2.2 60's to something. The best I have EVER achived with BFG drag radials is a 1.998 60'.
Old 09-17-2003, 12:47 AM
OctaneZ28's Avatar
Default Re: Best 60' on 2.73 gears?
See my sig.
I'm sure it's not the best, but I'm happy.
Oh yeah, this is on 245/50-16 Nitto Drag Radials.
Old 09-17-2003, 10:29 AM
boomcase's Avatar
Average for me is 1.83 to 1.87. All motor, 1.89 to 1.99 with spray, Nittos cant hold down in firstgear.
Old 09-17-2003, 04:22 PM
gillbot's Avatar
Well, I thought my 2.1-2.2's were sucky and this proved it. Anyone else?
Old 09-17-2003, 10:47 PM
GrapeApe's Avatar
my best is 12.06@114 with a 1.85 60' 2:73's suck because once they spin they spin faster and longer
Old 09-17-2003, 11:09 PM
koolrayz's Avatar
The 1.845 in my sig is my best. that was with the stock TC. tomorow the tci 3500 goes in
the nittos are just 245's
Old 09-18-2003, 11:59 AM
Lafngas98Z's Avatar
I am stock motored, stock suspension, yanked the front sway bar off, on 27" Hoosiers Ive pulled a 1.76 on the motor, and a 1.59 on a 150 shot with the 2.73's. I just got my new rearend in (8.8) with a 3.73 gear. I am hoping to blow those 60's out of the water tonight if the rain holds off!
Old 09-19-2003, 08:23 AM
Bowtieman4life's Avatar
I cut a 1.92 in my old 98 A4 with street tires an good track prep. Usually, 2.0 on street tires and stock converter. I smoke the sh$% out of the tires before staging and stalled to 1600 RPM's. I found that 2.73 are harder to smoke. Some of the guys with higher gears had to leave at a lower RPM using a stock set up.
Finally, don't swap gears. I've have heard horror stories about guys getting zero gains from a gear swap. If you want to lower your 60 ft buy a Vig 2800 or 3200 TC and some ET streets. I see guys running 1.5 to 1.7 60 ft with this set up.
Old 09-19-2003, 09:29 AM
LS1TECH Sponsor
foff667's Avatar
with just a borla and lid i was running off 2.06-2.07 60's having to go through the water on 235/55/16 stockers...not sure how much better i couldve done cuz that was with very little spin.
lata
Bill
Old 09-19-2003, 03:33 PM
gillbot's Avatar
I'm running a Yank 2800/3.0 now but it did nothing to lower my 60's. I just didn't think i was spinning but I may have been and didn't realize I was.
Old 09-20-2003, 02:52 PM
samz28's Avatar
i asked elsewhere. But 3000/3200/3500 ? i'm doing alot of city driving, want the benefits of a stall. is choosing 3500 stall with a 2.73 rear gonna be a pita driving in the streets?
I was looking at the TCI model since its price seems good. I don't plan to track alot (lack of time), but ya never know what you mind find on the streets.
I don't want a car that has to chirp em every time i have to move 20 feet..
Old 09-20-2003, 04:40 PM
gillbot's Avatar
With my 2800, you really can't even tell it's there IMHO. And it MAY be for sale soon if I can gather the cash to get my race converter!
Old 09-21-2003, 08:25 PM
MCBRIZ28's Avatar
My best 60ft is in my sig. which was without n2o. I have had real good luck with the kumho's and the 3200 vig has real good street manners.
Old 09-21-2003, 11:27 PM
99PTA's Avatar
See the sig..... Not too good i think
Old 09-22-2003, 12:41 AM
A converter is only good if you can hook. You need to run ET Streets with a converter.
Old 09-22-2003, 05:22 AM
gillbot's Avatar
That's what I'm trying next! I just can't believe the number who have cut 1.8's or lower, I was elated when I hit 1.998!!
Old 09-22-2003, 11:42 AM
koolrayz's Avatar
Samz28: I have the TCI 3500 with 2.73 and it is very streetable. You have to give it quite a bit more gas to move from a stop but it accelerates very smoothly. it doesnt get violent until you really put your foot into it.
Old 09-22-2003, 02:25 PM
jt093's Avatar
I cut 1.74's on motor and a 1.54 on 150 shot. Vig 3600, STOCK suspension, macs w/ ory, and a lid on 26x10.5/16 et streets. Best 1/8th mile 6.98.
Edit: I kind of forgot about the 224/224 112 cam...I'm so used to it that it seems like its not there LOL
Old 09-22-2003, 10:48 PM
Ragtop 99's Avatar
Maybe we have better track prep in our area, but I know many, many people (including me) who have run 1.6x 60' on nittos. With 2.73s and nittos, traction should not be an issue unless you have H&C or spray or a track that uses oil instead of VHT
Try 18 to 20lbs and heat them until you see smoke in your rear view mirror. You'll get your good 60'.
Old 09-23-2003, 05:33 AM
gillbot's Avatar
Well, I have nittos and ET streets. Maybe i'll take both and give the nittos another shot.
Quick Reply: Best 60' on 2.73 gears?
