Need advice on gears
Have a 99 A4 Z28 that currently has 2:73 gears in it. The car is pretty much just a bolt on car ( lid, ported TB, LS6 intake, Hooker LTs, ORY, Magnaflow Cat Back ) and will more than likely be staying that way, as it's more of a street car than anything else.
My question is this.....for what I'm using the car for, which gear set would be best? 3:23, 3:42 or 3:73?
I kicked around throwing a stall in it, but the wife will be driving the car as well, and I'm not real sure her and a stall would make a good match.
All three gear sets are fine, actually for the 3.23 and 3.42, you may just want to find a used axle and just toss it in there. Its prob cheaper then a gear swap.
I think in general 3.73 will be fine too, if the Mrs. knows how to drive and what to expect, you should also have no issues. She just needs to be aware that she has to respect the vehichle.
Probably the best quote of the day!!!!!!
Huggerorange73, Go ahead and get the gears and stall. You or the Mrs. shouldn't have any problems with streetability. You will be amazed in the difference with that stuff.
freeway isn't that bad, gas mileage did go down a few but if you keep your foot out of it you get decent mileage
but with street tires 3.42 you loose traction alot half way on the throtle and tire's break loose, heck even when I hit second gear and full throtle the tire's just spin.
it is nice to know that 40 mph i can spin the tire's :-)
now if I didn't drive 50 miles daily to work I would like to see how the 3.73 do.
