Will 2 series gears fit in a 3 series carrier?
I have an oportunity to get a great deal on a set of 4.10's and a gear install kit. The only problem is that the gears are for a 2 series carrier and my car has a 3 series carrier in it. I know that a 2 series gear is thicker, but will it fit?
Yea I don't think so either. I do have a 2 series carrier sitting in my garage that would accept the gears but I don't feel like swapping the whole rear just for a gear change. On the other hand, I would be able to install the gears right out in the open without being crammed under a car.
you have a rear in your garage with a 2 series posi in it and you want to swap gears out in your camaro. you will have to take the carrier out in the 10 bolt you have now in the car to put the gears in if you get them. so your so lazy that you dont want to take 25 more bolts out of another rear end to get the carrier out. you lost me man or you need the award for the most lazy person out there.
