Break in 3.73 gears??
Old 01-29-2009, 07:37 PM
crapyboy750's Avatar
Default Break in 3.73 gears??
I just got my car back with the new moser axles and the new 3.73 gears. The shop already did the heat cycles and they said i shouldn't floor it until about 200 miles of break in. Is that a good amount of miles for the break in period or should i wait longer?
Old 01-29-2009, 07:56 PM
jetlag's Avatar
https://ls1tech.com/forums/gears-axl...new-gears.html
Good read ^
I broke in my gears correctly, and they still whined. A guy in that thread makes a good point... about new factory vehicles, gears not broken in and they never whined.
When I got my 2002 F150 brand new, 6 miles on it, I raced everyone with it, took it off roading, etc, etc. Gears never whined one bit and I know I didn't "break them in" properly..hah Now I have a 08, it runs 16.7 stock..no gear whine..hah
Old 01-29-2009, 08:15 PM
Good read ^
I read that but theres not a right answer. Haha all i wanna do is put the pedal to the metal. lol
Old 01-29-2009, 08:27 PM
jetlag's Avatar
Go for it
Old 05-18-2009, 09:57 AM
rmkleman's Avatar
Same situation as me man, just got my 3.73's in last week, the shop did the heat cycles for me, said stay out of it for 200 miles, as soon as 200 miles hit i floored it (awsome) and now i have a pretty bad whine, loudest around 35-50 mph. Not sure if the pinion nut backed off or what? Guess i'll bring it back to the shop this week as i have never worked on a rear end before. Any suggestions? How did yours hold up after you put the hammer down for the first time?
Old 05-18-2009, 10:00 AM
01ssreda4's Avatar
if you floor it just roll into it. Dont shock the rear end by try to leave the line hard.
Old 05-18-2009, 01:01 PM
rmkleman's Avatar
I was rolling when i layed into it, now i have a whine, are my new gears screwed? i don't know what to do?
Old 05-18-2009, 01:27 PM
2camaros6702's Avatar
I just did my first install ever. I have worked in a very high tolerance job for 17 years now so it was not that bad at all for me. At lest not yet. LOL. I had about 40 miles on it when I kinda rolled into it just to see if I could fell the difference. I now have about 80-90 miles on them and I have got on it about 5-6 times now, still rolling on it in second every time untill I hit third and then off. I still have very very very little noise at all.
My biggest question is should I change the gear oil after the brake in?
Old 05-18-2009, 05:10 PM
ahhwataday's Avatar
drivetrain.com give them a call
ahhwataday's Avatar
Please post what they tell you to help the next guy that searches
Old 05-19-2009, 02:00 AM
01ssreda4's Avatar
yes, at about 500 miles would be good.
Old 05-19-2009, 02:07 AM
CarsandWomen's Avatar
Yup, like the man says, after about 500 miles. and make sure you add the limited slip additive if you need it. be sure to wipe off the magnet on the inside of the diff cover when you change the fluid, and recheck the fluid level after you drive it for 10 or 20 miles.
Old 05-19-2009, 02:18 AM
ahhwataday's Avatar
You are supposed to heat treat the gears. Drive stop drive stop drive stop. then get to high speed, then allow to cool down. Im not 100% sure if thats correct but drivetrain.com could tell you.
