sweet tech tip 4 you 9 inch and 12 bolt guys
Ok well I installed a moser 9 inch in my 2000 trans am wich recuires a 1 inch longer driveshaft and 12 bolts require a 1 inch shorter driveshaft. well I looked around at prices and I cant afford a 400 driveshaft at the moment and I trusted a steel shaft over aluminum if it has to be a shorter shaft. So I picked up a steel shaft from a 96 and damn if the shaft itself wasnt a half inch longer than my aluminum one. So I measured the insert that goes into the transmision and found out the one on the aluminum one was a half inch longer than the one on the steel one. So once I swaped the snouts ($40 in u joints) I had my 1 inch longer shaft for my 9 inch and have a 1 inch shorted one that should work with a 12 bolt.
Nice tip, this should help a lot of people out. Thanks. Bob
This wont work for everyone. Keep in mind if you have a lowered car, which majority here do, your length may be different yet. Always measure to be sure. But this is good info.
Jeff
Jeff
the snout on the aluminum driveshaft atleast the one on my 2000 trans am was a 1/2 inch longer than the snout on my 96 driveshaft. Also the driveshaft itself the aluminum one was a half inch shorter than the steel one so by swaping the snouts it gave me a 1 inch longer driveshaft than my stock aluminum one. And the aluminum one that now had the snout from a 96 was now 1 inch shorter.
2000 trans am driveshaft + 96 lt1 snout = 1 inch shorter than stock
96 driveshaft + 2000 trans am snout = 1 inch longer driveshaft
