Axle's
Old Apr 7, 2009 | 06:02 PM
lswon80's Avatar
Default Axle's
Looking for affordable new axles.. What companys do you guys buy from..
Im looking for some stocker replacements due to a warped axle.. For some reason something tells me I can get some good axles for less then 200 dollars a axle at autozone???
Old Apr 8, 2009 | 03:31 AM
MikeG's Avatar
http://store.summitracing.com/partde...47+4294851288+
Old Apr 8, 2009 | 08:25 AM
sroach20's Avatar
just buy some used ones, or watch the for sale section. i just bought an almost new set of mosers for $150 shipped.
Old Apr 8, 2009 | 08:34 AM
omcar's Avatar
i got a pair of Moser 28 splines for $225 from Summit or Jegs.
Old Apr 8, 2009 | 05:51 PM
lswon80's Avatar
thanks guys so the ones from summit are 2 instead of one for 255 that will be great..
Old Apr 9, 2009 | 04:30 PM
lswon80's Avatar
what is a 2002 rear 7.6 7.5 what is it ???
Old Apr 9, 2009 | 05:12 PM
sroach20's Avatar
7.6 28 spline and either 2 or 3 series depending on the size of your gears. 4 channel with tcs and 3 channel without.
Old Apr 9, 2009 | 05:31 PM
lswon80's Avatar
I just have the stock gears in my 02
Old Apr 9, 2009 | 05:37 PM
sroach20's Avatar
for axles all you need to know is 4 channel or 3 channel.
Old Apr 9, 2009 | 05:40 PM
lswon80's Avatar
how can i tell that I dont have traction control thats all i know.. you see your signature well mabey it should be mine
Old Apr 9, 2009 | 05:48 PM
lswon80's Avatar
think i just answered my own question 3 without traction 4 with traction.
Old Apr 9, 2009 | 06:05 PM
1BADBLACKBIRD's Avatar
yes...if you have traction control, you have a 10 bolt, 7.625, 28 spline, 4 channel ABS...this means you have two electrical plug in thingys on each brake disk backing plate.
If you do not have tractin control....then you still have a 10 bolt, 7.625, 3 channel ABS...this means you only have one electrical plug in thingy in top of your rear end housing.
The traction control axles need to have a specail sized portion so the reluctor ring can be pressed onto them so the electrical thingys can pick up the difference in axle speed from left to right.
I would get new Moser axles directly from them.
Old Apr 9, 2009 | 07:37 PM
sroach20's Avatar
with traction control you would also have a button above the radio that says asr.
