torsen question
Old Apr 13, 2009 | 03:10 PM
ElkySS's Avatar
Default torsen question
how should a torsen diff act when the wheels are off the ground and you spin the tire?. when i do it the other wheel spins at the same speed in the same direction. then if i stop for a minute and tun it again the other wheel wont even move for about 1/2 a rotation. is this normal? im trying to track down a clunking noise that only happens when i take a left. i cant tell if its suspension or diff. if i dont get an answer ill probably pull off the cover later
Old Apr 13, 2009 | 03:16 PM
ElkySS's Avatar
also i should add, i dont feel the clunk through the shifter
Old Apr 13, 2009 | 03:27 PM
alamantia's Avatar
did you spin them when the car was in gear/park or neutral? If it was in gear/park one wheel should spin the same rpm in the opposit direction, if the trans isnt in gear/park the drive shaft will spin and the wheels will just do whatever they want.
Old Apr 13, 2009 | 04:39 PM
ElkySS's Avatar
no it wasnt in gear. ill try doing that and see what happens.
Old Apr 13, 2009 | 04:55 PM
ElkySS's Avatar
well i tried again with it in gear. it acts like an open diff. they spin different ways but its pretty hard to turn.
Old Apr 13, 2009 | 07:23 PM
ElkySS's Avatar
does this sound normal?
Old Apr 13, 2009 | 10:02 PM
Weezzer's Avatar
Yes, its normal. When you turn the rear wheel in one direction - the adjacent wheel will spin in the opposite direction.
Old Apr 13, 2009 | 10:38 PM
ElkySS's Avatar
i meant the part about it being hard to turn, but thanks!
Old Apr 14, 2009 | 01:15 PM
ElkySS's Avatar
anyone else?
Old Apr 14, 2009 | 01:21 PM
01ssreda4's Avatar
i would pull it apart and try to inspect it, its a very simply designed posi.
Old Apr 14, 2009 | 02:43 PM
9987ta's Avatar
The clunking you hear is normal...let me guess...if you coast at 30mph and turn the wheel to the left or right you hear it? My 1st torsen was broken and the car would one wheel pulling out on stones etc. with a new torsen pulling out on stones loose gravel etc both wheels will move the car.
Old Apr 14, 2009 | 06:49 PM
ElkySS's Avatar
i doubt this noise is normal. its really loud and only in one direction. if i turn right i wont have any noise at all.
Old Apr 14, 2009 | 09:52 PM
ElkySS's Avatar
well i popped the cover off and found nothing wrong. the right side axle tube was leaking so i jacked up the body and let the suspension sag while i welded the tube on and nothing changed
Old Jun 17, 2009 | 10:07 PM
99Z2ate's Avatar
Do you mean that your original Torsen did that because it was broken? Mine is doing that EXACTLY. Now it's starting to make other noises as well. I'm beginning to hear a whining from the rear getting higher pitched as I increase in speed. On top of this, the drivetrain feels quite "loose," unlike any other fbody Ive driven. Does anyone know if this sounds like a bad torsen?
Old Jun 17, 2009 | 11:18 PM
01ssreda4's Avatar
sounds like it....
