Rebuild Rear end??
Old 05-08-2009, 01:52 AM
rdemarce's Avatar
Default Rebuild Rear end??
I was thinking of rebuilding the rear end instead of replacing it with a different one. Is it possible to stay with the 10-bolt and rebuild it to handle 500 HP? It's an automatic transmission with 3200 stall and I don't plan on a lot of track time. What would be the best things to upgrade and what would be a waste of time to upgrade? Or would it just be cheaper to replace the rear-end completely?
Old 05-08-2009, 04:05 AM
EPP
EPP's Avatar
https://ls1tech.com/forums/gears-axl...olt-break.html
Check this link out. Bob
Old 05-08-2009, 04:23 PM
rdemarce's Avatar
Hmm, so I guess I should look into a 12-bolt maybe or the 9''. I heard a transmission girdle (or whatever it's called) will help it...anyone know anything about that?
Old 05-08-2009, 04:37 PM
CavPat's Avatar
Check out this link as well:
http://www.highperformancepontiac.co...ild/index.html
It's up to you. If you're going to put drag radials on it an try for best ET's, then I'd say replace it with a 12 bolt or 9 inch. But if it will only see the track on occasion, with street tires, then I would say build the 10 bolt. That's just my opinion though.
