Strange vs. Moser vs. Ford 9"
Originally Posted by Classic
The 9'' will be more or less indestructable for that power range if you set it up with decent parts. Avoid the aluminum center section for street use.
And just as Fireball said - you can ship it via UPS which is 100 times more convienent than truck freight - believe me.
On a related note, what are the general weights of each if anyone knows?
Strange 12 bolt
Moser 12 bolt
Moser (or any) 9 inch
Moser (or any) 9 inch with aluminum center section
Stock 10 bolt
Assuming 4.10 gears in each if it matters?
Just curious.
That could be a problem if you want to reatain your ABS as I'm sure you do...
I don't think you can use a 9 inch with ABS but without ASR, it's either ABS/ASR together or neither one at all.
Strange 12 bolt
Moser 12 bolt
Stock 10 bolt
Just curious.
Originally Posted by 1ScrudeDude
Got the ABS, but don't got the Traction Control. Where does that put me?
Strange 12 bolt
Moser 12 bolt
Stock 10 bolt
Just curious.
Strange 12 bolt
Moser 12 bolt
Stock 10 bolt
Just curious.
Yup, still want to keep the ABS so I went with the Strange 12 Bolt. Thanks.
This is why I went with Strange! Is there a guarantee that I will have the perfect 12 Bolt without any problems?
NO.
But I like my chances vs. a Moser. Customer service is everything. It's a lost art in today's world....
NO.
Well since strange and moser use the same posi There is no difference.
I have a 2000 $ 10 bolt in my car. Actually never broke the 10 bolt, but broken the 12 bolt twice..
I now run a spool, but highly recommend a 9" to anyone that is the market for a new rear.
Sometimes it's what happens after the fertilizer hits the oscillator that makes the difference between a good company and the I-don't-give-a-****-one.
I looked at a 9" like you suggested, but I want to keep my 3 channel ABS active. FWIW, I am only sending 413 ponies to the rear wheels, and do not plan to spray out of the hole with slicks. For me, it's all about a NA motor and letting the clutch go with Nittos at 3000 to 3500rpm.
Still hard on the rear, but I feel good about my chances maybe 10 times a year.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I have a 2000 $ 10 bolt in my car. Actually never broke the 10 bolt, but broken the 12 bolt twice..I now run a spool
What else was done to beef it up? A lot I assume for $2k invested LOL.
I'd love to keep the lighter, 'less power robbing' 10 bolt in there.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
You still have a 10 bolt? With a spool?
I'd love to keep the lighter, 'less power robbing' 10 bolt in there.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Bruce
I never thought that the components were any different. I was pointing out the difference in customer service reputation.
Yeah I got what you mean't probally didn't come out right.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I only have about 430 hp to the wheels and no Nitrous.. It borke on a 4500 dump..
I also have a freind who had a bolt on car destroy the differental.
I understand wanting to keep the ABS though, good luck.
Thanks Bruce for clarifying. Yes I have a 12 bolt, but would never, never recommend anyone buying one. seen way to many of them break in the past year.
i'll be stepping up to BSPz28 set up when I get rich..
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#32
Gotcha Moose
I am quite amazed that these 12 Bolts are breaking. They were once deemed "bulletproof."
I still don't think there's a perfect soluton to this rear end dilemma. The 9" is now the bull of the rears, but if you have 3 channel ABS you are screwed. Also, it is the most power robbing.
Maybe the 8.8 has the potential to combine both worlds, but no sponsor sells them. Yet.
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
#33
Originally Posted by Hardtop
I think what Moose is saying is that his 12 bolt is just a $2000 10 bolt.
I was at the track one day when he broke it. I've said it before, if you have a hard running M6 car get a 9". I've got one of those $2000 10 bolts too, and will be trading up to a 9". ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Thinker](https://ls1tech.com/forums/images/smilies2/thinker.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I agree, if I were to ever step up to real power I would ONLY go with a 9 inch, problem is I don't have traction control.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#34
Which means no operable ABS.
For resale value, and for streetability, I went with the wimpy 12 Bolt. Hardcore racers say screw the ABS, but I haven't got that mindset.
Maybe that'll change?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
#37
Another vote for a Stange 12 bolt. ESP for your application. I would run a spool or at a minimum an Eaton Posi. I think the 9"is overkill for a low 11/high 10 second car. I have installed MANY Strange 12 bolts. They are great quality and as said above, they have awesome customer service. FWIW, I have a Moser in my car with a spool and if I could do it over again I would get a Strange....
#38
my 12-bolt has 40k miles and has only been set up once (by moser before i got it). it has been in three different cars, my 98 TA, my buddies 02 TA, and now my 02 SS. it has never broken anything and has been beaten to hell. probably has over 150 passes on slicks and god knows how many on street tires and drag radials. the 12-bolt will handle all the power most of us throw at them and is much more streetable. my buddie with the 02 TA bought a 9" but then got rid of it. it wasn't as streetable, meaning he had no abs and made the car ride a lot different. also messed up the torque arm since it dosn't mount quiet the same. along with the fact that the factory sway bar won't work either. my vote, if you car is a STREET car is to get the 12-bolt. much less hassle and can easily handle a heads/cam, small shot of nitrous car.
#40
Originally Posted by 11 Bravo
What is with this talk of a 9 inch with no abs? I talked with my shop today, and they are getting me a Moser 9 inch with abs and tcs.
3 channel-->no Traction Control--->bye bye ABS.
