Breaking rear ends with what sized tires?
What tire size and power levels are the 10 bolt rears holding up to? Most of the stories about breakage I've heard are with slicks on a track. Is there anyone breaking them with small factory 8" tires? How about on the 9.5"? Or the 11" ZR1's?
I'd like to go to a set of black ZR1 wheels (9.5 front 11 rear) but I'm worried about my rearend.
My car is an M6 with 3.73 gears. '98 Z28.
I saw the picture of that firebird in GMHTP pulling a wheel with slicks on a stock axle, but that was with an auto.
The car is driven hard, but it will never see slicks, I don't care much for 1/4 mile times. When I've been on the track, its always been with full weight, full pressure in the tires, and no thought toward the amount of gas in the tank. I haven't been to the track in this car yet, I'll have to wait till next spring as the track has closed. Hoping for low 13's.
The car is pretty stock now (gears, filter, hypertech), but that'll be changing a little in the next few months (LS1 edit, lid, FTRA), and then come April it'll be modded a bit more with headers and an ORY with a cutout. I have to wait for e-check, else I'd do it sooner.
So the real question is: will a modded Z28 with an M6 on 11" rear wheels with street tires destroy a 10 bolt rear?
Its all luck with the stock rear. I've seen bone stock M6 cars break it with street tires (mostly dr's and slicks) and ive seen modded M6s running et streets for years with no prob. Most everything says its gonna break if you run it hard. Especially with stickies, but on street tires your gonna buy yourself some time with it. JMO.
Probably the biggest factor on what kind of abuse the rear will stand up to is if you have an auto or a manual. My auto has seen multiple 1.5x sixtys at the track with ET streets, while a guy I know that has an M6 broke his stock axle on regular tires having never even used anything other than street tires. Another tip for avoiding axle breakage is to stay away from wheel hop. It's hard on a lot of parts.
Originally Posted by z98
Still not sure what I'm gonna do. I have a friend who can get me a bolt in 12 bolt for $900, I guess I'll go that route before the wheels/tires.
I raced a entire season with my 10 bolt and dr's when I had boltons. I cut 1.7's all year long and a 1.60! Then over the summer my 10 bolt bit the dust on a launch off idle with the H/C
i made 468rwhp and 560rwtq and have been in mine 3 times with 9 runs. 2 times with gears breaking and 1 with the carrier breaking. 1.41 and 1.43. if i keep it in the 1.5s it is ok but don't push it.on 28x9x15 et drags.
Originally Posted by 1ScrudeDude
Opinion please...does the rear TA cover buy any time or luck with the rear end?
