Midwest 9 inch, vibrations help
WE had some trouble getting the vibrations to go away on the car when it was 1st installed. But a set of adjustable LCAs and some adjusting of the pinion angle and we got the vibrations to go from 60MPH(starting at ) up to 120MPH. Now im not going 120 MPH very often but at the track or maybe the random street race it will get up there hehe
Problem is the vibration shakes the whole freaking car. Im assuming the the pinion angle must still be off to some extent. The car is lowered so I am wondering if anyone else has installed one of these rear ends and had/solved this problem? I was thinking about looking into some V6 rear spings or some other set to raise the rear up about 1 inch.
The car drives just fine at any speed below 120, no whine or grinding or vibrations. Just once I hit that 120 ish mark it shakes the crap outa me lol.
Any suggestions?
neg 2 - 3 degrees on what we set it at, which i thought neg 2 was the money spot on these cars hehe
After talking to a couple people this was going to be my game plan. I was going to adjust it down half a degree and drive it for awhile and see how it did and just do 1/2 degree adjustments till i found a sweet spot. Just good to hear someone on here confirm it hehe
If its vibrating, the DS is out of balance.
I went down this road and it aout killed me. My DS was out of balance. I sent it to PST and they repaired. All vibes gone period.
But like I said before I had this same exact problem before however the speed was at 60 mph. Once I was able to adjust the pinion angle better with the adj. LCAs the MPH moved from 60 up to 120. The vibration at 120 seems a little more intense than what it was at 60 though.... which im sure is in part do to the fact im doing double the speed haha.
Before i noticed around 70mph i would get a very slight drone sound ( blamed it on the exhuast ). This time with the adjustment it seemed to be more quiet around this MPH. Then took her up to 80, nada, 90 nada, 95ish the vibrations started and around 100 they were getting close to what it was at before around 120.
So it seems by adjusting the angle less negative by .5 degree it moved the vibration up in MPH ( opposite of what I and others thought lol ). So next attempt will be to put it back and add 1/2 a degree and give her a run.
Does this seem odd to anyone else lol. Is there anything else I should be looking at? I know drive shaft balance has been brought up, would tire balance have anything to do with it? By the observation posted above it leads me to believe that I am on the right path just need to find the sweet spot for my ride height and setup.
Dicked around with the pinion angle for hours. Vibes remain.
Replaced the front u-joint. Vibes remeain.
Took it back to shop 1 that balanced it. They did again and the weights were now in different places. Vibes remain.
Replaced the rear u-joint. Vibes remains.
Dicked with the PA some more. Vibes remain.
Double checked R&P setup. Vibes remain.
Replaced all brake rotors. Vibes remain.
Ran car on jackstands without wheels or rotors. Vibes remain.
Installed Rockland NW tailshaft bushing. Vibes just a little less but the bushing failed due to tight clearance. Vibes remain.
Installed OE rear tailshaft bushing. Barely better. Vibes remain.
Took the DS to shop two for balancing. Vibes remain.
Had the tires balanced. Vibes remain.
Sent the Strange DS to PST for balancing. Vibes gone.
The pinion angle is not Just the angle of your rear end. It is the defference between the angle of your drive shaft and the angle of your rear end.
https://ls1tech.com/forums/drag-raci...ion-angle.html
This thread Madman is stating that you only need to adjust the rear end angle. So I am going to have to assume that the negative angle he is suggesting would be based on what your drive shaft angle is as well.
I watched the BMR video and it seemed a little more confusing than helpful ( plus other posts said the same ). However the video and the Sticky for pinon angle seemed to try and state the same concept.
So what does a lowered, 9 inch rear end car guy need to measure to get this damn angle right?
We did try the BMR method and the cars vibrated like crap.We tried Madmans way and it got worse.Not the best for street driving. Going by traction my car still dead hooks 1.5 60's.
You stuck the angle finder on the rear of the trans to find that angle. Then you placed it on the bottom of the rear and adjusted the rear to zero out based on the tranny angle?
