Are 3.73 worth it?
If you want to be on the border of performance and compromise 3.73s, just dont say no one told you so.....poor gas mileage caused by higher rpms at cruising speeds. But i'ts not that bad.....a friend had 3.73s on his mustang a4 too and he didn't complain too much, and if you ask me tall gears are the only way to make those gay *** 01 GTs to at least move.
If you had an M6 3.73s would do you perfect.....and actually had they offered the 3.90s when I was swapping out gears, I might have tried those instead.
Final tidbit... taller gears tend to be weaker than shorter ones, also whine less.
Good luck....
Now to make driving around town easier from what I heard the 3.73s will be better with the 3500 stall. Would that be correct? The car is just a bolt on car. LS6 intake, Long tube headers, LID, CATS!, and a powerpac. Ill be porting my TB while they are doing the installs and Ill do the bump stop mod then as well.
I have a 224 cam but I wont install it until I get springs and hardened push rods. Maybe in 2 months after the vette is finished ill have the cam installed.
Or you can go to www.f-body.org/gears and see for yourself the difference between the 2.
As far as the track gains go, I wouldent worry about it. Get a high stall converter for that.
thats a good thing.
