9" tilting up
Old Oct 4, 2009 | 09:57 PM
nealws6's Avatar
Default 9" tilting up
put on a 9" in my 2000 trans am, but it tilts up without the torque arm. Is that normal? Also I have a umi torque arm and hits the under car (drivers side) when I down shift or do a hard takeoff. Thanks for any info.
Old Oct 4, 2009 | 10:12 PM
STEEPSS's Avatar
have you checked / adjusted your pinion angle? By tilts up, do you mean the pinion tilts up (towards the tunnel) ? Do you have a short torque arm ( tunnel mounted )?
Old Oct 4, 2009 | 10:28 PM
nealws6's Avatar
yea it tilts up towards the tunnel without the torque arm on. Have the umi tunnel brace mounted adjustable torque arm (part#2203).
Old Oct 4, 2009 | 11:48 PM
Zmg00camaross's Avatar
sounds normal with no torque arm the springs push down on the backside forceing the front to point up and its a pain to reinstall the torque arm to then
Old Oct 5, 2009 | 12:34 AM
00nbmz28's Avatar
jack up the body and let the rear hang and it will be eaiser and wont tilt up.
Old Oct 5, 2009 | 08:04 AM
cody161's Avatar
this is normal, put a floor jack underneath the rear end and jack it up into the car some, this will help rotate the rearend back down.
Old Oct 5, 2009 | 08:12 AM
the_merv's Avatar
Actually when you jack it up the Rear points up more.. when the full weight of the Car is on it is when it sits closest to level. I know this cause I put my new Torque Arm in the other day.
With the Rear in the air put a Jack under the Swap Bar and lift it there..that will help straighten it out.
Old Oct 5, 2009 | 10:14 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Is the car also lowered?
Old Oct 5, 2009 | 10:49 AM
nealws6's Avatar
Thanks. What do you guys do about the torque arm hitting under the car.
Old Oct 5, 2009 | 11:03 AM
HUNTER02SS's Avatar
Your torque arm should have multiple set's of holes where it mounts to the center section. Mount the torque arm as close to the center section as possible. this will keep you from hitting the tunnel. UNLESS your car is lowered and the top bolt on the torque arm is hitting. Other than that, you should be fine.
Old Oct 5, 2009 | 12:15 PM
the_merv's Avatar
Mine hits too..that big steel Bracket that bolts to the Moser Housing smacked a nice little hole in the Tunnel back there. This happened at the track on my launches, street driving is fine.
Old Oct 5, 2009 | 03:17 PM
nealws6's Avatar
Yea my car is lower. I have bilstein shock and springs
Old Oct 5, 2009 | 05:59 PM
00nbmz28's Avatar
oh oops. i though thats what i did when i put the 9" in my car but i guess i forgot. dont listen to me lol
Old Oct 5, 2009 | 09:33 PM
the_merv's Avatar
No prob man..I think he got the idea.
Old Oct 6, 2009 | 10:49 AM
nealws6's Avatar
Well I'm going to put my stock springs and shocks on see if that helps. Raise it up a little only on the back.
