12 bolt gear noise
i am debating whether or not to get a 12 bolt or 9 inch. i would go with a 12 bolt if the price is right tho. but my main concern is gear noise. i remeber reading somewhere that i think something with the torque arm that it stresses the 12 bolt and picks up gear noise? is this correct. how many 12 bolt owners picked this up.
My moser makes some noise.Never heard the theory about the tq arm causing it.Mine is straight gear whine,i have a richmond ring an pinion and have heard that they make more noise than other gear sets.
Just turn the radio up,thats what i do!!!!
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Ya I think its on epp website where the torque arm stresses the housing I believe and that what causes it. My 10 bolt whines and its so loud when just cruising in 5th and 6th that's what I really want to avoid. I guess I'll just spend the extra hundred or 2 and get a 9 inch
Yes it will get noisy. I had a 12 bolt in my 01 Z/28 and hated it. Changed gears 3 times, set up by someone that knows what they are doing. A dozen or so 5-6000 rpm dumps with QT Pros and the rear howled like a banshee. Bought Moser 9" with 4.57's, 35 spline axles and a locker. Stayed quiet after many passes at the track. I would never buy a 12 bolt for a M6 car. I won't buy one for the A4 car I have now. I'm going to look at a S60 when I upgrade the rear on this car.
the 12 bolt will get loud after a few launches with a 6 speed. it will eventually break teeth.
i have broken mine a few times. dead quiet until the first pass. then loud.
i have crushed the sleave, broke a pinion bearing, broke a carrier spiders gears and ring gear . then i went to a spool with a chromoly solid spacer(damaged the ratech one) and then broke the ring gear again.
i will be using a 9 inch next year i hope
I sell the Moser 12 bolt and the Moser 9 inch for the same price. Bob
http://www.exoticperformanceplus.com....html?item=145
Moser 9 inch.
http://www.exoticperformanceplus.com....html?item=146
Moser 12 bolt.
Moser 9 inch.
Moser 12 bolt.
