PICTURES of the new Rear end...take a look.
http://98hc4mula.shutterfly.com/
well here is a website I just added pictures to, lets see if it works.
the rear end is a Midwest Fab 9 inch with a wavetrack and 4.10 gears, cut 3 inches from each end. 1/2" studs, 35 spline, strange axle and carrier. long torque arm, Adjustable LCA and PST 3.5 Aluminum DS.
wheels will be a set of Billet Specialties Street Lites with 4.75 BS
here I have the brake lines all plumbed and ready to be mounted on the car....
other side of the brake lines
getting ready to go in
see how close the DS is to the DS loop....
this is just to show how close the brake line is to the TA mount, it has plenty of clearnace if you route it this way.
ARH Catted Y Pipe and ARH headers also Installed
showing where the TA hits the Y pipe, or is resting I should say.
I am also waiting for SJM abs delete and line lock kit to be installed as soon as I get it, and some other small odds and ends before I can go test this thing at the track...
let me know what you think.
thanks
David
thanks
David
ok let me know if you are not able to see pictures from that website.
Im just waiting for my new wheels to get here, I have been waiting since January for the Billet Specialties to arrive.
ordered some 17x11 with 4.75 back spacing and 17x7 for the front.
also waiting on the SJM abs delete and line lock kit to finish it up.
Eric at Midwest chassis has been very helpful in all this, only thing I didnt like was the long wait for the stuff to get here.
the long torque arm is touching the ARH Y pipe even after placing the TA in the 3rd hole. We are going to correct this soon hopefully.
All you gotta do is copy the IMG code to each pic and then paste it on your new post but that's on photobucket very easy each IMG code comes up next to each pic you upload. Never used shutterfly before! Nice setup you go to the track much? Post some pics on STFB.
I will but I cant freakin figure out how exactly to post the pictures....I feel like a dumb *** lol. I will be going to Edinburgs track as soon as I get the wheels. the car will be ready for some shake down passes.
PM me your number so we can get together when I get this completed man.
David
David
David
David
Very nice work done on that rear. I got the exact same setup as you coming hopefully this week. Been waiting a while for it now due to the red powdercoating instead of the black you got.
thank you, I recommend anyone who is doing this to bend their own lines, its not hard at all, it took me probably about 20 minutes tops. I had to figure out the bends and that was it. other than that, the assembly went pretty smooth, the backing plates and the bearings pressed in fine all I had to do is bolt the center section and slide the axles in and I had a completed rear.
I spoke to Eric today, he is swaping me the long TA for the short version as well as the DS loop because of my set up and the rubbing issue. I will have that stuff early next week as well as the new wheels. I waited for this rear since Mid January, same with the wheels, I was told that Billet specialties are out of stock on the 17'" hoops for the rears.
that is the only thing I did not like about all this, the time it took for me to have the parts I needed. but I think that is just part of the game.
I would do it again if I had too. Eric has been very VERY nice in answering all my calls, I think I called him like every other day lol. he also took his time and responded to my emails which were not short by any means.
Thumbs up and a rating of 5 stars to his service. he is a stand up guy who is willing to go the extra mile in helping his customers out.
all I want now is to enjoy this thing...........
Yea I know what you mean. I have been waiting since the start of feb. I know it will be worth the wait in the long run. So on those brake lines you had to bend yourself. Did the splitter come with the rear or did you have to buy that??
Hey thanks for post up the pics! I ordered the same rear end, short ta w/ loop, lca's, phb, sfc's, and a driveshaft. If all goes right my stuff should be here middle of next week.*fingers crossed* But your pics are very helpful, expecially for bending the brake lines. Your car is sweet looking man, should deff move out at the track!
The splitter I had from before, you can reuse the stock one since its the same size. the rear will come with the bracket for the splitter, all you have to do is mount it first then mock up the lines.
I actually had to cut and re-flare the line from the car which connects to the splitter bc I wanted to use this stainless line. The reason I did that was because I needed to put a different fitting for this line to make it mate correctly.
the assembly is straight forward. it was very simple to do, just make sure you know how to set the angle lol, that was my only hold up....
well the lines need to go under the DS loop bracket but its a moot point bc I am taking it out and replacing the TA with a short one, that TA brace will have a Safety loop integrated to it. I was unsure how to do it initially until I saw some pictures. regardless, its fine like that, it doesn't touch anything though.
Eric is definitely a very stand up guy, great customer service and patience overall! I too was calling him like everyday when I was doing my setup.
Hopefully you get everything together so we can hit the track!
