Rearend Question
Old Mar 23, 2010 | 02:01 PM
ninjai_ruken's Avatar
Default Rearend Question
I have a full spool rear end(Mods in sig), But unfortunately I am not really a big drag racing enthusiast. I can respect drag racing, and I do partake in it once and a while but my passion is Road Racing. I like curves, hills and dips that being said my full spool is starting to annoy the living hell out of me. I have a stock rear end and gears out of a 1995 V6 Bird. I would like to keep the 4:10 gears but be able to make a turn with out tire scrub. What are some options I might have besides dropping money on a new rear end?
Old Mar 23, 2010 | 07:50 PM
bigj2717's Avatar
Wait so you're taling about replacing the 12 bolt with a stock rear? Why? Just take out the spool and replace it with a trutrack or something else
Old Mar 24, 2010 | 11:34 AM
No, I do not want to go back to stock. I would like to be able to drive on the street with out ratcheting tire scrub every time I turn or turn while backing up. Just wondering what can be done.
Old Mar 24, 2010 | 11:58 AM
bigj2717's Avatar
Ok well yeah just replace the spool with something else
Old Mar 24, 2010 | 12:14 PM
98hc4mula's Avatar
look into the wavetrack, its supposed to be bad *** for street and hold its own at the track. warranty is: you brake it and we replace it.
Old Apr 12, 2010 | 03:59 PM
I am looking for something designed for Canyon Carving Road Racing. Any good products out there?
Old Apr 12, 2010 | 04:15 PM
technical's Avatar
You want a Torsen differential. Instead of a positively 'locked' rear that breaks free around turns you want an 'unlocked' rear that applies traction when you need it. Much nicer when approaching a turn fast. Also won't 'push' nearly as hard.
Torsen will work well for what you are looking for. A WaveTrac will work well also, but I don't think they work with anything other than 35 spline axles.
Old Apr 13, 2010 | 12:26 PM
The Reply I received from Torsen
"Unfortunately, the largest differential we make is the one for Frankland, which also happens to be a 12 bolt unit that is specific to their quick change rearend.
Thanks for the question and interest in Torsen"
Old Apr 13, 2010 | 03:54 PM
Exeodus's Avatar
Can't use just get a posi differential from Moser?
Old Apr 13, 2010 | 04:12 PM
technical's Avatar
That's odd, because I seem to remember them in the larger trucks and SUV's from the factory. E.g. Tahoe/Blazer/Suburban. Memory fail.
